[QUOTE=gtsum2;791838]Yes you can. I asked etrailer that question and since the b&w puck hitches are locked into the pucks you can use a sidewinder with them. They do not recommend using a sidewinder with the b&w turnover ball hitch though[/QUO
From b&w:
When you turn, the king pin wants to twist. But when a wedge won’t let it twist, bad things can happen.
In fact, we’ve had people call us and say their Companion hitch was literally ripped from their truck because of this kind of product.
Not only could you be creating a very unstable and unsafe situation for yourself, your passengers and other drivers, but if you use a product with our mounting system, and that product hasn’t been manufactured and/or tested by B&W, our warranty will become void.
We’re not trying to disparage these extended pin boxes. They work just fine with other B&W products that attach with rails and pucks, but not the Companion Fifth-Wheel Hitch or Companion Slider Fifth Wheel Hitch that has a single-point of attachment. It’s not that the Companion is weak or unsafe, it’s just that this newly designed pinbox drastically changes the usual way 5th wheels are towed.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
