Old 10-28-2013, 07:55 PM   #11
I think so. At the same time, you should be visually inspecting that the pin is where it needs to be and that everything is closed, locked, etc. like it needs to be. That visual inspection is very important to ensuring you're properly hitched.
Do you have a trucking background? I think I read on rv.net that someone said their big rig's hitch would close and stay closed just by hitting the pin. They didn't need to do anything else to the hitch. No RV fifth wheel hitch works the same way, as far as I'm aware.
Yes I do have a cdl. I know when I back in to a van trailer with a semi it hooks automatic. And I do inspect to make sure it is hooked properly.
albuilder is offline   Reply With Quote
Old 10-28-2013, 07:56 PM   #12
My Reese 16K will latch and lock when backed into. Then all I do is flip the safety latch over the handle and padlock.
Name:	To hitch, rod must be removed.jpg
Old 10-28-2013, 07:58 PM   #13
Ford Idaho's Avatar
Originally Posted by OldCoot View Post
The bearded guy is one of the engineers that designed the hitch. He is the one that worked on mine in Goshen along with the narrator who is the other engineer that designed the hitch. Both were super nice and very professional.
Very cool, I never get to meet the people who have hands on with the build, just the sales guy who knows squat.
Old 10-28-2013, 08:00 PM   #14
Yes but if you watch the video you can see where he releases the handle manually. On the husky hitch. That is what I have to do.
Old 10-28-2013, 08:03 PM   #15
Got a complete explanation on how and what to lube and what not to lube. They even borrowed my torque wrench for the rest of the day as they had forgot to put theirs in the van.
Old 10-28-2013, 08:10 PM   #16
Ford Idaho's Avatar
Hahaha!
I bought a second one to leave in the trailer so I would not 'forget" it.
Old 10-28-2013, 08:12 PM   #17
CZNEDY's Avatar
Originally Posted by albuilder View Post
I have a huskey 16 k fifth wheel hitch my jaws on the hitch don't close when I back in to the fifth wheel. I have to get out and release the handle to close the jaws. Is this normal?
Since you have the reeserevolution, you will need to spend time hitching and un-hitching. From my experience, at first it was easy and hitched the first few times (I was lucky). If you have the wedge installed, there are a few factors that can making hitching up a little more tricky. Angle of approach, trailer level TV not level, pin too high.....and a few more. It just takes some getting used to but I have found that if I am a little crooked backing in and the wedge doesn't go straight in, the jaws will not always close. Sometime they will close all the way, but then I will have to roll forward a 1/2 inch to take the pressure off to lock the handle all the way down. BUT, since it is not completley locked in, I do the pull test and then the jaws lock in. Most of the videos out there helped alot, but the best thing to do is read your hitch manual, hitch up and un-hitch on a flat surface a few times to get the feel for the right angle and the right height. Once you do this about six times, mark your landing gear and then you can judge where you need to be when you are on anuneven surface.
One other thing, Reese shows you how you can back in at any angle when you are n a tight spot. Only do this if you have someone to work your tailgate or you will damage your front storage compartment.
2018 BERKSHIRE 34QS
2004 Jeep Wrangler and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 10-28-2013, 08:17 PM   #18
CZNEDY's Avatar
I forgot to mention. I have the reese R16Hitch, the one they show in the video at the very beginning. Watch the beginning closely, there is no pin in the latch handle.
2018 BERKSHIRE 34QS
Old 10-28-2013, 08:24 PM   #19
tomjsas's Avatar
I never have issues with my pullrite hitch. As long as I have the approximate heigth right, it slides up tne saddle and locks in every time. I also have not had issues being off center either but would agree that if you are very far off to be careful with the tailgate!
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 10-28-2013, 08:26 PM   #20
Hahaha!
I have 2 Williams 250#/' snap wrenches, one at home and one in the trailer. Also have an old style beam that only goes to 150 lb/ft.
hitch
