Old 06-28-2012, 09:35 PM   #1
Brigitte
boubou's Avatar
hitch for 5th wheel
what kind of hitch would I need for a 5th wheel on Ram QC 1500? have to decide by tomorrow...
I don't know anything about the types of hitches and application but looking for best option for the 5th wheel. Money does matter but I am willing to spend the $$ to have a safe and easy hitch to use. All I was told is that I need a slider hitch and I can have manual or automatic.
Recommendations anyone?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 06-28-2012, 09:49 PM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
My 2 cents...
If you want an automatic operation, easy to use and essential maintenance free ( few daps of lubricant through the year), the PullRite Superglide is the way to go. It's going to be the most costly hitch but you'll appreciate it when you encounter a tight turn at a busy gas station or campground and all you have to do is drive and maneuver without getting out of the truck.
The manual sliders have a lot of steps involved to set the hitch for operation, especially not good when you either have people behind you wanting to pass or caught in a heavy rain! Many brands available, just need to find one you can manage and maintain with your liking.
You'll find many people who don't ever use their slider but like having the option if needed...in this case, opt for the manual sliders as they will be less expensive than the automatic.
Good luck .)
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 06-28-2012, 09:51 PM   #3
Rsgtivr6's Avatar
It depends on the 5'er. Some are designed with short boxes in mind and can be used in a 6.5' bed without a slider hitch. My dad has an '06 Crossroads Cruiser 28RL behind his '11 Sierra Denali HD with the 6.5' bed and doesn't need a slider. Did you find a 5'er under 900lbs pin? Remeber, 5th wheel hitches are a lot heavier than WDH in most cases. A slider can weigh 150-250lbs depending on which one.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-28-2012, 10:05 PM   #4
fast murray's Avatar
I have a QC Ram and use one of those older hitches that has the brackets that mount over the wheelwells. It is not very adjustable and does not move back and forth. I think I could hit the cab with the camper but I pay attention. I've pulled into goofy gas stations while pulling a BBQ pit behind the 5er and have no trouble. If I get a different truck, I'll get a hitch that pivots side to side but I don't care if I have a slider.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 06-28-2012, 10:22 PM   #5
Brigitte
boubou's Avatar
@ Rsgtivr6, the hitch weighs 1055 lbs wich is pretty close. I think 100 to 300 lbs difference will be ok
as for money, pullrite sounds really nice, I'll mention it tomorrow.
So far, the tech mentioned the Reese super glide??? and he's pricing the manual and automatic glide. I will definitely pick the automatic.
He also mentioned two different type of installs, over and under the bed? I don't know what this means....
I'd rather be scaling teeth (my profession) than thinking about all of this, so, I am thankful for all of your help!
Superglide 2700
Timbrens
Old 06-28-2012, 10:54 PM   #6
Rsgtivr6's Avatar
Over the bed is a bolt on top rails, but when hitch is removed, you still have rails on top. Under is bolted underneath the bed to the frame w/holes drilled through the bed and generaly allows for a cleaner bed when hitch is removed since the rails are underneath.
Old 06-28-2012, 11:01 PM   #7
Brigitte
boubou's Avatar
if I don't plan to remove hitch, does over or under the bed make a difference?
which is better in your opinion?
would both stand at about the same height into the bed?
I plan on closing the tonneau cover when not towing
Superglide 2700
Timbrens
Old 06-28-2012, 11:10 PM   #8
Rsgtivr6's Avatar
I can't really weigh in on that too much, but my dad's neighbor has his mounted above and can still close a tonneau of need be. It's a Reese non-slider in a 2008 Chev 2500 HD CCSB. Not sure what specific one though.
Old 06-29-2012, 07:40 AM   #9
camper_Lucy's Avatar
IMO Pullrite is the best option as the the jaw swings around the pin and it is very easy to verify that the hookup is correct and it will not fail. vs clamping jaws style hitches. I did not need a slider but I have never heard anything bad about the Pullrite slider and a lot of members here use it. In addition you can setup the Pullrite so that the hitch and rails remove so you get a completely clean bed if you need to remove it to haul something in your truck bed.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 06-29-2012, 07:47 AM   #10
So which 5'er are you buying?
Len & Cheri is offline   Reply With Quote
5th wheel
