Old 10-04-2012, 07:52 PM   #1
Stormrider151's Avatar
Hitch heads
Hopefully Saturday I'm going to pickup a new truck. Now I have to consider resetting the hitch head. I'm going from aTWD to a 4X4 so the ball height difference will be substantial. The hitch head is currently set for 21 3/4 in. In as much as the hitch head is set to the trailer should I just reset the head to as close to 21 3/4 on the new truck? O r go through the whole process from scratch. Thanks for the help.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 10-04-2012, 08:04 PM   #2
kz08h5's Avatar
Definitely make the hitch the same height as your original and the trailer. Do to suspension differences between the vehicles you will probably have to adjust the bars to get the setup right.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 10-04-2012, 08:47 PM   #3
Triguy's Avatar
I do all of the adjustments when changing TV's.
Definitely start with the former height measurement assuming that is the exact trailer coupler height.
I would check and adjust for the weight distribution measuring the wheel wells or at a scale. Wheel well measurements are fine if you don't have a scale handy. I don't see what WDH you have, but this entails adding or subtracting washers with my Equal-I-zer.
Finally, check and adjust the trailer angle as needed.
It's almost the whole setup, but good to do to make sure you have it right.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-04-2012, 08:49 PM   #4
That's what I was thinking. I'm guessing that the same tilt should work also. At least it should close and only needing a little tweaking to get it right. Thanks for the help.
