Old 05-05-2016, 08:42 PM   #1
tuckerdog1's Avatar
Hitch height
This has probably been discussed, but I searched & could not find what I'm looking for. Just looking for learned opinions
I have read & been told verbally, that if you can't get you TT perfectly level while towing, it should be a bit a bit high. Also read & been told the opposite, that it should be a bit low. Gut feeling is a bit low would be better.
My situation is this. I have two drop hitches. One has the TT an inch high. It looks like more, but multiple measurements show 1". I suppose adding load to either the TT or the bed of the truck could bring that down closer to level. But maybe not. The other drop hitch has the TT 2 inches below level. And again, I suppose added weight might increase that drop a bit.
These are small numbers, and may not amount to a hill-o-beans. But which setup would you go with?
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB ( Mine )
2015 Genesis 5.0 ( Hers )
2016 Windjammer 3029W Platinum ( Ours )
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
tuckerdog1 is offline   Reply With Quote
Old 05-06-2016, 04:15 AM   #2
shorthorn's Avatar
Surely there is an adjustment point between those two? Are you using any kind of weight distribution?
My old equilizer setup had holes every 1.5" I believe to dial in hitch height.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 05-06-2016, 05:55 AM   #3
TURBS's Avatar
Go inch high and call it a day
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Old 05-06-2016, 06:35 AM   #4
clr
X2
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-06-2016, 10:50 PM   #5
m2kamp's Avatar
I'm towing 3/4" high in the front. Wish it was dead level, but I'm tired of messing/wrenching with it and it pulls good. Maybe, when I get some more time I will adjust it again.
It doesn't matter too much for single axle trailers but with tandem axles I would think tongue high would place more weight on the trailers' rear axle?
Tongue low, more weight on the forward trailer axle?
If one is close to trailer GVWR, could be exceeding axle/tire rating?
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 05-09-2016, 06:01 PM   #6
Maybe try a ball with a 2 inch rise to get you level.
Big Red and 30WR is offline   Reply With Quote
Old 05-09-2016, 09:54 PM   #7
tuckerdog1's Avatar
I was unaware the ball itself could be had with different heights. I'll check into that. Thanks.
Tuckerdog1
Old 05-13-2016, 10:12 AM   #8
Blog: RVroadtripper.com
hbillsmith's Avatar
The Andersen WDH has an adjustable shank. It comes in either 6", 8" or 10" with associated numbers of holes available to adjust height.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-13-2016, 07:02 PM   #9
Too Tall's Avatar
Adding more tongue weight really won't help the height adjustment because you'll pick the rear end back up with the WDH. Ideally, you'd like to have your tongue low enough so you can PU the rear end of the truck to within an inch of unloaded height and trailer level.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is online now   Reply With Quote
hitch
