Old 11-21-2012, 09:42 PM   #1
Hitch help
Ok 4 days into the first trip with the E2 hitch and it seems to pull fine on 2 lane roads at 60 to 70 mph but highway driving with lots of 18 wheelers is a nightmare. I was thinking the hitch was over kill for the 19 foot trailer pulling it with a Avalanche. Any help or suggestions. Thanks Michael
Hornnumb2 is offline   Reply With Quote
Old 11-21-2012, 10:08 PM   #2
Dave_Monica's Avatar
If you're having issues with 18 wheelers moving the camper around, you don't have enough sway control. The only way to get more friction for increased sway control is through more weight transfer on the hitch.
Dave
Old 11-22-2012, 07:03 AM   #3
MtnGuy's Avatar
2 lane roads at 60 to 70 mph ?? The speed rating for ST tires are 65 mph. Many 2 lane roads (at least around here) are 55 mph and under. Relax, slow down, and enjoy the scenery. Be safe.
Now onto the other problem. You need to do the fender measurements spelled out in the instruction manual to make sure you are getting enough weight put back on the front axle.......or you could actually have too much weight put back on the front axle. After tweaking the hitch with the fender measurements, then a trip across some CAT scales would be good to confirm your setup. A trip across with the spring bars in place, then without the spring bars, and then just 1 with the Avalanche alone will give you all sorts of good information. Keep load and passengers the same during each weigh-in.
