Old 03-29-2012, 09:01 AM   #11
Snowman53's Avatar
Thanks for insights
Many thanks for the suggestions and insights. To be clear the receiver hitch is welded to the frame of the trailer. Very strong. That part was not the problem. The problem we experienced was the up and down motion which caused the bikes to move somewhat and for mine to override my wife's which scored up her handle bar shifter. Also the Yakama rack's components loosened up during our 2,500 mile trip last fall which made the movement worse. Tightening them was helped a great deal.
Although I have carried bikes on the roof, our issue is that we often tote 17' sea kayaks with us. So they are on the roof of our Chevy Suburban thus no bikes up there. I will likely try the Yakima Hold Up rack as my web research suggests that it is the most robust and secure of the tray racks I have seen. After some local testing if needed I will consider additional ties to the trailer as needed. Anyone have any experience with tray racks?
Snowman53 is offline   Reply With Quote
Old 03-29-2012, 09:20 AM   #12
MtnGuy's Avatar
The problem is not how the bike rack is attached to the bumper, but how the bumper is attached to the trailer frame. Rugged Brown had the welds break between the bumper and the trailer frame from just carrying his spare tire, although I think he said he had carried bikes on the bumper previously. There are some pictures floating around of that weld tear, and I will see if I can find those.
Old 03-29-2012, 09:23 AM   #13
MtnGuy's Avatar
Check out post #7 & 8 here: bike rack???
Old 03-29-2012, 09:35 AM   #14
Triguy's Avatar
Snowman,
I have the Yakima Holdup plus 2 that can carry 4 bikes. We use it to travel to races and also with our kids' bikes. The nice thing about this hitch is that it supports almost any type of bike and almost any size. It won't do recumbents, though.
The hitch with two bikes (the plus two part bolts on and off) is very sturdy and I highly recommend it. The plus 2 extends out from the truck quite a bit. I have it on right now as we are on vacation and am always a little surprised just how far back this thing goes. Even with four bikes, there is very little bounce.
I have only used it hitched to our truck; not the trailer so I can't address that through experience.
Whether two or four bikes, though, the rack has carried our bikes many thousands of miles over the last 4 years. The hitch bolt screws in providing a secure attachment to the receiver and helping to minimize bounce.
You can attached a lock to the bolt. This protects the hitch from walking away although the bike rack is HEAVY so I don't really worry about it. There is also a long cable lock you can buy to secure the bikes to the rack to keep the bikes from walking away.
Speaking about the weight. One person can attach the 2 bike rack but two are really needed if you add the plus 2 attachment. Its both weighty and very bulky set up for 4 bikes.
I check and tighten all the all bolts before every trip and I recommend you add two battery powered red LED lights for viability.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-30-2012, 09:24 AM   #15
Snowman53's Avatar
Very helpful. I will start with the two bike set up and then go from there. We typically travel as a couple as the kids are grown and the three of them share the old Coleman pop-up. I am encouraged by the stability of the Hold Up. If at all possible would like to carry kayaks and bikes on our trips and would rather not have to choose. Thanks again.
Old 03-30-2012, 01:11 PM   #16
caper's Avatar
There are bike racks that mount over the propane tanks. A much better idea then having 200lbs bouncing around at the back to the trailer. I know some people have had their bikes on the back for several years, but as stated the trailers are light weight and not made to have anything hanging off the back. The bikes might not bounce on the back of a truck but they will be bouncing at the back of the trailer. Good luck with your hitch. When I purchased my TT the dealer refused to add a hitch to the frame. He informed me that the TT was not built to have a hitch on the back. He said that if the frame did not crack there was a possibility that the side wall could crack at the corners of the slide out. Have fun and stay safe.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-30-2012, 01:21 PM   #17
Snowman53's Avatar
Bikes and Kayaks
A propane tank-region bike rack is promising. Thanks for the suggestion. I will look into it. Will hold off on the Yakima Hold Up for now as I know the rack is heavy and then there are the bikes to add. I admit that with the ultra light trailer I have been sensitive to the amount of weight we add, especially to the rear.
Old 03-30-2012, 01:39 PM   #18
pbrackney's Avatar
I toured the Forest River Flagstaff/Rockwood factory a few weeks ago and asked the question to the warranty supervisor about adding a hitch to the back of the trailer by welding it to the frame for the purpose of a bike rack. He responded that he would not recommend that at all. It would void the frame warranty for the trailer and you may end up getting cracks in your fiberglass or the frame could bend due to the bouncing of the bikes. His comments were referring to the lightweight TT and 5th wheels. The frame is just not designed for that amount of weight with bouncing.
Just some more "food for thought".
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
bike, bike rack
