02-11-2013, 06:15 PM
Hitch noise
We tow a Mini Lite with a factory installed hitch. I've noticed a metal on metal sound occasionally when towing. I THINK it's the ball and receiver, but I'm not sure. I grease the ball, so it's lubed properly. Are there any adjustments on the hitch clamp? I would definitely appreciate any help.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
02-11-2013, 06:18 PM
Is it a weight distributing hitch? Are you sure it isn't the bars sliding when you make a turn? Ours took some getting used to, and then the dealer said that where they had not previously recommended lubing those points, the latest thinking is a little grease on there won't hurt and will certainly sound better.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
02-11-2013, 06:19 PM
Always Learning
My friction sway bar would creak and moan when turning when I had the popup.
02-11-2013, 06:31 PM
This not a weight distributing hitch. Never thought about the stabilizer bar being the cause!
Duramax/Allison
02-11-2013, 10:56 PM
you should be using a WDH if you're pulling that trailer with the MDX.
i'll bet your owner's manual will require using one, for a trailer that size and weight.
what you're calling a factory hitch is actually a hitch RECEIVER.
it's what you put a hitch into.
and what you're calling a "stabilizer bar", sounds like a anti-sway bar, which does no weight distributing.
did the dealer tell you that you didn't need a WDH?
02-12-2013, 08:07 AM
Ok, I got the terminology wrong. I always considered the receiver a hitch, never gave it any thought. I know the anti-sway bar does no weight distributing. In answer to your question, I wasn't told by the FR dealer I needed anything but the receiver/hitch. Now you've got me wondering! I will get my manual out and investigate - and get back with you. I honestly have no idea how a WDH even attaches to the tow vehicle nor the towee! I hope that term isn't too technical! I really am grateful for the response!
Duramax/Allison
02-12-2013, 08:32 AM
Need a photo of you hooked up (like this) to help here.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
02-12-2013, 09:21 AM
Ok, I'm up, got my eyes opened now and got the owners manual out re the hitch. The vehicle manual clearly states: "A WDH is not recommended for this vehicle." I don't grease the connecting points of the anti-sway bar, never gave those points much thought. I use a wire brush on the slide to keep it clean and tighten it for expwy driving. The sounds I hear occur when driving straight, not in turns. So, what I still wonder is whether or not the clamp on the tongue should be/can be adjusted?
Duramax/Allison
02-12-2013, 10:30 AM
Are you using the correct size ball? Also, grab your draw bar and see if you can move it up and down at all. Even the slightest bit of play will sound harsh inside your vehicle. If so, you can drive a small wedge between receiver and draw bar or they make a clamp that will quiet things down also.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-12-2013, 10:48 AM
Ah ha! Yes, there is some play between the receiver and the bar! Never gave that a thought! Regardless of what your wife says, you really are a help! Thanks. I'll go find a wedge thingy.
Duramax/Allison
02-12-2013, 10:49 AM
Always Learning
This is correct for anti-sway bars. You don't grease them and should keep 'em clean.
As for the sound when going straight... I'm out of ideas. Good luck!
02-12-2013, 12:21 PM
You are 1/2 correct,the ball sockets on each end should be lubed! Youroo!!
02-12-2013, 12:26 PM
Always Learning
Good point and I agree!
02-13-2013, 11:45 AM
daydreaming about camping
Just out of curiosity, what is the tow rating for your MDX?
I think you are most likely on the right track that the hitch is moving inside the receiver. However, you should pay particular attention to your receiver and make sure there is no damage.
Finally, as Herk suggested, a picture is worth a thousand words.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
02-13-2013, 10:16 PM
The MDX
According to the manual, the towing capy is 5K. However, a mechanic told me it was good for 7K. I think our TT comes at the low 4K. No, we haven't weighed it loaded. But next trip out, I'll stop at a local granite quarry and ask if they'd be so kind.
Duramax/Allison
02-13-2013, 11:23 PM
02-13-2013, 11:33 PM
I am guessing his shop is looking for work, or he could use the overtime pay.
02-14-2013, 07:49 AM
Towing capy
The mech who told me about the 5K vs 7K is an independent mech. His business is mostly minor repairs, tires etc.
Duramax/Allison
02-14-2013, 09:16 AM
Not to disparage your mechanic, but what proof did he offer that it is OK to ignore a manufacturer's limit?
02-14-2013, 09:43 AM
Unless one of Acura's engineers in Tokyo appears on your doorstep and tells you that, I would treat it like a political commercial, 1% truth, 99% used car salesman BS. I am slightly less diplomatic than Herk...
Getting back to your MDX - you really need to find a CAT scale at a truck stop. Watch this video for the how to weigh:
It will give you the weight on your front (steer) axle, rear (drive) axle and also the trailer axles. Best $10 you will ever spend, I promise. Then take it back across and un-hook the trailer on the trailer pad, to get your unhooked and true trailer weights. This will also allow you to figure your tongue weight. All that for $1 more!
Come back with those numbers and the guys here can tell you a number of things.
