Old 09-17-2016, 10:32 AM   #1
BeeGee's Avatar
Hitch questions
Please tell me why this hitch is designed to pivot the ball on a slant? Answer is it supposed to be allowed to move up and down during use?
2012 Ford Lariat F-350 Super Duty
2014 Forest River Cherokee Wolf Pack 27 TH
BeeGee is offline   Reply With Quote
Old 09-17-2016, 10:52 AM   #2
BeeGee's Avatar
Here is a pic
Old 09-17-2016, 11:03 AM   #3
raspivey's Avatar
It's a weight distribution hitch. It's designed to be used with spring bars of varying stiffness (weight capacity ). The bars are anchored to the frame with either chains or a bracket of some sort. When the rear of the truck squats, the bars attempt to angle farther downward. The chains or brackets prevent this and the bars will act as a lever to push more weight onto the front of the truck, counter acting the lifting that occurs when you apply weight behind the rear axles. Some weight will be taken off the rear of the truck and some will be transferred to the front wheels and the trailer axles. The angle adjustment allows for fine tuning it to increase or decrease the amount of tension on the bars ( and therefore, the amount of leverage applied ). The more downward the angle, the more weight transfer.
Old 09-17-2016, 11:07 AM   #4
raspivey's Avatar
Old 09-17-2016, 11:13 AM   #5
wmtire's Avatar
It looks like you are missing the nut/washer to the top adjustment bolt.
You can even see the outline on the hitch of where the washer was.
Without the nut/washer on this top bolt, then the weight of the trailer is pivoting the hitch head all the way down, which you can also see as the position of the top bolt.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 09-17-2016, 11:16 AM   #6
The Angle is for Setup adjustment! After Proper setup the Hitch as Pictured "Round Bar Type/with Friction Bar Ball" is to be "Fixed in place by the 2 Bolts" as well as some have "Washers to locate a Positive STOP,and others have Serrated Washers! Youroo!!
Old 09-17-2016, 11:58 AM   #7
Bottom line, ABSOLUTELY IT IS NOT supposed to pivot during use. It should be locked in a position with a bolt and washers to provide a positive stop.
Old 09-17-2016, 12:17 PM   #8
raspivey's Avatar
I had meant to add that and got sidetracked. Not just any washers and bolts...don't try to just tighten a regular bolt, nut, and washers and use it. It needs to be the hardware designed for that particular hitch. Otherwise, if it were to come loose it could be...bad.
Old 09-17-2016, 12:32 PM   #9
There is supposed to be one of these (eccentric bushing) on that bolt plus a lock washer and nut.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 09-18-2016, 10:36 AM   #10
X2!
larryo is offline   Reply With Quote
hitch
