Old 12-07-2019, 01:16 PM   #1
Hitch Receiver sticker numbers question
Hi all,
I have a 2016 Chevrolet Colorado that I will be using to tow a small travel trailer. I have a question about the numbers on the sticker (picture attached). Am I correct that the 900# number is max weight for the receiver and also meaning max tongue weight allowable on the receiver? I apologize for upside down picture. If there's a way to fix please let me know.
I understand how tongue weight effects payload.
Name:	Colorado receiver.jpg
Monchi is offline   Reply With Quote
Old 12-07-2019, 01:30 PM   #2
YEP, 900lbs tongue weight maximum, 7,700lb trailer weight maximum.
I
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
DougW is offline   Reply With Quote
Old 12-07-2019, 02:11 PM   #3
Hatchdog's Avatar
Fixed your pic
Here you go. I’m sure you understand that your truck weight ratings most likely will be different than the hitch ratings.
2023 Forester 2851 SLE
Hatchdog is offline   Reply With Quote
Old 12-07-2019, 02:54 PM   #4
bikendan's Avatar
Those max numbers are for the receiver ONLY and not necessarily what your truck is spec'd for.
Depending on how your truck is configured, you could have less tongue and weight capacity.
Old 12-07-2019, 03:00 PM   #5
Thank you all for clarifying and the picture fix. The truck is rated for only 7000# and I have 1450 payload available so I will hit that way before I would want to get close to that heavy a tow.
Old 12-07-2019, 03:54 PM   #6
bikendan's Avatar
You have the right numbers to get started with.
And check the truck's owners manual and go to the Towing section. It should have no WDH/with WDH numbers listed.
Old 12-08-2019, 12:45 PM   #7
So GM allows a 11.7 % tongue weight with their hitch at max tow rating. Seems Ford is always 10%.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 12-08-2019, 04:15 PM   #8
I consider 10% tongue weight an absolute minimum. Terrible things can happen with tongue weights below that number.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
hitch
