Old 02-27-2019, 03:54 PM   #1
Travelinman 2018's Avatar
Hitch size
Bought a E-Pro19FD, 390 lb TW, 2800 dry, 3890 GVWR. Buying a Husky Centerline TS . The come in 400-600 or 600 - 800 TW. Just wondering if anyone has had experience with these, and which would perform better. I understand that weight on my truck, on or behind the rear axle will add to the TW. ?
Travelinman 2018 is offline   Reply With Quote
Old 02-27-2019, 04:05 PM   #2
DieselDrax's Avatar
If you assume up to 15% of GVWR on the tongue that puts you just under 600LB, if it were me then I would go with the 600-800 bars to ensure sufficient WDH capability instead of not enough.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 02-27-2019, 06:16 PM   #3
Sham183
mopwr4me2003's Avatar
For some of the Husky hitches you need to have a minimum trailer weight of 4000# for the hitch to work correctly. I think itís the one with the hydraulic pistons with it. I canít get the manual to download right now but I would double check that before you buy just in case.
mopwr4me2003 is offline   Reply With Quote
Old 02-27-2019, 06:20 PM   #4
Sham183
I got it to download finally. Donít know if this is the model your looking at or not. Click image for larger version
Old 02-27-2019, 07:12 PM   #5
Go West's Avatar
The hitch that Mopwr4me references is the Husky Centerline HD system which utilizes compression cylinders. OP is purchasing the Husky Centerline TS, a four-point anti-sway hitch design. This is the hitch that I use.
I went with the 600-800 lb bars for my trailer which is 5,200 lbs on the road with a tongue weight of 780 lbs (measured with a hitch scale).
For my trailer’s hitch weight, the 600-800 lb bars provide very effective weight distribution to my tow vehicle's front axle. Using the 600-800 lbs bars (for my trailer's weight) produces a relaxed towing experience, even at the top range of the hitch's rating. Using heavier bars than needed may produce a stiffer ride for the truck-trailer combination.
My advice to OP: for your E-Pro 19FD, go with the model rated for 400-600 lbs hitch weight.
Name:	Truck Only CAT Scale.jpg
ID:	197753   Click image for larger version
Name:	Truck - Trailer CAT Scale.jpg
________________________
2017 Cherokee Grey Wolf 25RL
2017 Nissan Titan SV 4x4
Husky Centerline TS
Go West is online now   Reply With Quote
hitch
