07-21-2011, 02:10 PM
Hitch? Sway bars? Recommendations?
While I realize this question is generic in nature I'd like to know if any one has any recommendations about hitches and sway bars etc.
I have heard from some friends that Reese isn't as strong or "Heavy Duty" as Equal-i-zer... and that I wouldn't need the Equalizer due to the lighter weight of my TT.
Towing a 4300lb trailer with a half ton chevy through the mountains and areas of high winds.
07-21-2011, 02:14 PM
Moderator
The Reese Straight Line (Dual Cam), Equalizer 4 point, Blue Ox with integrated sway control all should work well.
You size spring bars to your trailer, depending on the hitch weight. With a 4300 lb. trailer, I can't imagine the hitch would ever be over 800 lbs, so that might be the size you need.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
07-21-2011, 02:17 PM
While the Reese with a Sway Bar might do the job I have had both and can tell you there is no comparison when it come to the Equalizer for peace of mind. Had the Reese on a smaller trailer and only had one or two white knuckle moments but when I upgraded to 31 feet the sway bar couldn't handle it....
2000 F250 Ext Cab 7.3L Diesel
2011 Flagstaff Classic Superlite 831 FKBSS
Fleet of Canoes and one Kayak
So Many Rivers so Little Time!
07-21-2011, 02:25 PM
Moderators' Assistant
the most popular WDHs are the Equal-i-zer and the Reese Dual-Cam. both have built-in sway and are priced well.
IMHO, the Equal-i-zer is simpler and doesn't require any drilling.
i've heard the Reese D/C is better for heavier trailers.
your trailer is about what mine weighs and i pull with an '07 Avalanche. i love my Equal-i-zer and it's been a "setup once and forget it" system.
RVW has it for around $430 with free shipping.
just a suggestion, this is asked constantly and there's tons of posts answering the same question.
you might want to do a search and you'll have lots of info available, to help with your choice.
that's how i ended up deciding on the EQ.
07-21-2011, 03:03 PM
Thanks for the responses...I now have a foundation for the research to begin.
Bikendan - Appreciate your response and input. As far as the web page I am still getting accustomed to the forums and research. I just got done reading several different threads. Thanks for the direction...a lot of information.
07-21-2011, 04:04 PM
flyfishn
I've had Reese and Equalizer in the past. I liked the equalizer 4 point, but made some irritating noise while backing up. I now installed the Blue Ox Sway Pro and love it. It is especially nice with the quality powder coat finish and all the new BO Sway Pro now come with the chain cam for ease of installation and fine tuning sealed grease fittings and very user friendly.
Fly Fishn
2011 Mini-Lite 1809S
2008 Dodge Durango Hemi w/Diablo tuner
Prodigy P2 Blue Ox Sway Pro
07-22-2011, 09:29 PM
Glad you posted that gtakato! I just picked up a Blue Ox to replace a friction bar wdh and was starting to 2nd guess myself with all the positive things said about reese and equalizer.
2006 Nissan Titan
2011 Salem 26Tbud
Blue Ox BXW1000 WDH
Nights Camped 2011- 17
07-24-2011, 05:37 PM
OK, after doing some research I have some drastically different numbers.
The GVW of my trailer is 7465lbs
Dry weight including all options(Fictional - Bikendan) is 4365 lbs
I am estimating the weight of the trailer (When loaded) at 6721.8 lbs which includes the following:
1500 lbs of gear
796 lbs of fluids ( 36gal water, 30 gal gray, 30 gal blk tk at 8.3lb)
60 lbs of propane
Safe tongue weight of 1008.27 (15% of 6721.8)
= 779lbs safety margin of my Silverado's tow rating (7500lbs)
and the following hitch combinations
Blue Ox Sway Pro BXW1500
Equal-i-zer 1200/12000 4 pt hitch
Reese Dual Cam?
Open to criticism or suggestions....
07-24-2011, 08:10 PM
Moderator
What make and model trailer do you have ???
Speculating here. With a GVWR of 7465 lbs., you probably have 2 3500 lb. axles, with a dry tongue weight of 465 lbs. You will have to do a lot of up front loading to get that up to 1000 lbs.
It is good figure a worse case scenario, but seldom do you carry liquids in all of your tanks at the same time.
1500 lbs. of gear is a lot......I travel with about 800 lbs.
Any of the hitches listed would work great, but with a 465 lbs dry tongue weight (not sure about that, but guessing from your figures), 800 lb. bars may be adequate.
2008 Surveyor 263
07-24-2011, 08:50 PM
My thinking is when you buy the 2nd hitch we all know at some point we're going to get a bigger trailer why not get the bigger hitch to began with?
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 593 |
| 112 members and 481 guests |
| 1l243, 5Galvs, Adony, alphadog99, Andy R, autorot8, Bandit114, Barney1, bclemens, biken201, bikendan, bob34787, bobbygee, boubou, brandon0214, brookside, Browndog, Cafjackracing, case1175, chiro, chof16, CM BOXERS, comfun1, cyclepuck, dashonthedash, dasimser, Dave_at_FastwayTrailer, ddemme, dec1952, deerslayer, Dennis Carpenter, Deputyseven, DGrissom, djorgensen3, Dukejr, dummin4fun, dunnnc, elind, frfan, gbpacker, Gizzerd, Gman88, Gollum, Happy Vibe, HWII, Indy Steve, isz, itat, JamesR, jasni, jes520, JJones, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, Kevin-and-Julie, kfroe, kjoh75, LFugate, lochsa, lowbubba, Mad4sax, merlin66043, mesquiteguy, mhartzel, mia, Mr. Legato, mrmurph, mtnguy, pappcam, Pharmofish, PrairieBoy, punkaccountant, pwrplay, ret2006, rjshiflet, rkswyo, rodcop9405, Rogue69, ronhanson, Rsgtivr6, rstewart06, RV Guy, SabreMarv, SabreSam, Sailfish Bret, sbond, ses, SimchaSabre, skippy31405, snowbrid, spike, steeleshark2, Steve7575, texashatter, TheFlagGang5, Tincup13, Titleguy, tking1866, tmmar, toleworks, tomjsas, torben, viper48, VTX Al, wayne anthony, we2lovecamping, whj77372, Wichitalineman, woodchomper |
| Most users ever online was 996, Yesterday at 11:04 AM. |
