Old 04-05-2019, 04:40 PM   #1
tom39's Avatar
Hitching view improvement Suggestions
Well as much as I love my new TV, one thing that has presented itself as a problem is trying to align the kingpin to the 5th wheel hitch. In my former truck which was a single cab 8' bed, it was simple because I just looked out the rear window or rear view mirror and hit it right the 1st and every time. My new truck however is a 4-door crew cab with and 8' bed and I cannot see the pin or the hitch.
My initial thought was a mirror of some type that could be magnetically held in place while hitching. The link doesn't have a magnetic base but I could easily add one of those.
https://www.amazon.com/Hook-up-Mirro.../dp/B00ET990WW
The second thought was those yellow balls on a telescopic rod with a magnetic base. I have a set of these and I will try it but I am not so sure that it would work as well as I would like.
https://www.harborfreight.com/magnet...hoCRrYQAvD_BwE
My latest thought was to get a backup camera something cheap that would only get limited use and not remain in place when not in use. My thought was to make a base the attaches to the hitch plate. This way I could get a visual on height of the kingpin and also alignment right to left.
https://www.amazon.com/gp/product/B0...7N7L6TO0&psc=1
Anyway, this is all still in the planning stages but I would like to see if anyone else has a method they use and have great results. Or let me know what you think of my ideas and if you have a recommendation of something better, please let me know.
Thank you in advance for you thoughts and suggestions.
Tom
2011 Rockwood 8288 SS UL
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
tom39 is offline   Reply With Quote
Old 04-05-2019, 04:58 PM   #2
fonzie's Avatar
I use this camera for hooking up my travel trailer, works great and can be used for other tasks.
https://www.amazon.com/Swift-Hitch-D...-1-spons&psc=1
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-05-2019, 05:03 PM   #3
I mounted one of those wireless license plate frame backup cameras on some magnets. Hang the frame wherever you need it for a better look when backing up.
My backup camera frame also contains an obsolete California license plate..just for grins.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 04-05-2019, 05:23 PM   #4
tom39's Avatar
fonzie, thanks for the suggestion.
I really like that camera but I am not a real fan of the price. I am also not sure, no matter how I spin it, that I could convince the wife that this was a necessary expenditure.
Old 04-05-2019, 05:26 PM   #5
tom39's Avatar
upflying, is the camera that you use a permanent mount or do you only set it into place when you want to use it? Also, is the camera hardwired or is it Bluetooth or WiFi?
Old 04-05-2019, 05:37 PM   #6
It's wireless but I am not sure of the communication method it uses. The frame came with a device that looks just like a smart phone. It is plugged into a cigarette lighter and it shows what ever the frame camera is pointed at. I hold the "smart phone" screen in my hand while I'm backing.
It doesn't connect with my phone or Bluetooth.
The frame camera has a battery that is recharged with either a built in solar cell or a USB cable.
I didn't use mine as a license plate frame because the angle of view is too shallow in relation to the ball and coupler. I needed to mount it higher on the back of the tailgate, hence the temporary mounting of the frame with the magnets. When you are finished backing or hitching, pull it off and store it in a box.
Old 04-05-2019, 05:54 PM   #7
fonzie's Avatar
You could use this camera and adapt it to your situation...
https://www.walmart.com/ip/PYLE-PLCM...LCD-S/50744922
Fonzie
Old 04-05-2019, 06:49 PM   #8
tom39's Avatar
I like this one. For the price, I would not be out much if it didn't work out. I think that I am going to order it.
Thank you for finding that one for me.
upflying, is this something that is similar to the setup that you are using?
Thank again,
Tom
Old 04-07-2019, 07:22 AM   #9
bareftn's Avatar
wow your wife wont help you hitch up?
when I drop my gooses neck trailer I leave a 4x4 on the ground so all I have to do is line up straight and slowly back up and the 4x4 stops me and I am right on
bareftn is offline   Reply With Quote
Old 04-07-2019, 07:36 AM   #10
clr
I had the same problem when I changed TV as you did. My solution was one of those yellow hitch balls on the telescoping rod. I align the yellow ball with the king pin slot ahead of the hitch and attach the magnet to the rail of the hitch and pull the yellow ball up until it is above the truck bed.
This works much better than I expected. If fact I leave the ball in place most of the time just push it down so that the it is below the cover and close the cover.
Simple and cheap but of course some type of back up camera would also work.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
hitch
