Old 09-30-2015, 08:36 AM   #1
Honda 2012 CRV Issue
New to RVing and just travelled from Fredericksburg, VA to Beckley, WV towing a Honda CRV 2012. No lights or other electric items on yet the battery was dead after five hours on road. Do I need to pull a fuse? Didn't indicate I had to in the owners manual. Leaving in two days for Kentucky and want to get this issue resolved before then. Thanks for any suggestions.
Mall Man is offline   Reply With Quote
Old 09-30-2015, 11:33 AM   #2
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
Honda recommends when towing for long periods to remove the 7 1/2 amp accessory radio fuse.
Hope this will solve your problem.
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 09-30-2015, 01:08 PM   #3
coupevillefish's Avatar
You can also install a switch. The bad news is that either option will loose the program settings in the radio according to our dealer. Our brake unit sends a trickle charge to the battery but we haven't towed far enough yet to know if that is sufficient.
coupevillefish is offline   Reply With Quote
Old 09-30-2015, 10:44 PM   #4
HONDAMAN174's Avatar
Yes and it is not fun to get to. I suggest getting some needle nose pliers and extra of those micro fuses cause they will easily fall behind the panel.
Just glad to get away
Old 09-30-2015, 11:39 PM   #5
Kenny kustom's Avatar
Small solar panel on the dash to provide some charge?
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 10-01-2015, 08:08 AM   #6
Wow... dead battery after 5 hours? That's a lot of power being drawn! My bet is there is something more than just the radio drain going on. They're good for normal parasitic current draw, but a solar panel won't stop that kind of discharge.
matwiyj is offline   Reply With Quote
Old 10-01-2015, 12:03 PM   #7
Need to find where the drain is coming from. Disconnect battery and put a meter in the circuit. See what drain is. Pull fuses one at a time to find drain.
Harkerr is offline   Reply With Quote
Old 10-01-2015, 12:20 PM   #8
Be cautious with this.
Most cheap meters are fused at 10a.
Fluke goes up to 20.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 10-01-2015, 01:05 PM   #9
I installed a battery maintainer by brake buddy that you can find on Amazon for $20 or so. Hooks into your 12V feed from the 7-way plug harness. Worked like a charm for over 10,000 mile Alaska journey except for one time when the connection came loose. Sure beats pulling fuses and installing cutout switched.
lakewood90 is offline   Reply With Quote
Old 10-01-2015, 01:14 PM   #10
Send a message via Yahoo to carluv
I put a switch on that fuse. I lost at least 5 behind the kick pad trying to pull or reinstall the fuse. I have a 2014 with navigation, and that staying on killed my battery in about 5 hours.
Haven't had any more problems.
carluv is offline   Reply With Quote
