Old 06-10-2015, 07:49 PM   #1
Who Dares, Wins
doc73's Avatar
Hooking safety chains to 2015 chevy 2500
So I went to hook up the our trailer to check the fit of everything. Everything went well until I tried to hook the safety chains up. Looks like Chevy fully boxed around the hitch on the 2015 and my chains will not fit around the boxed out cut outs. I am thinking of some smaller shackles or quick links but I think they might not span the openings.
What did you all do for your 2015 2500's? Thanks.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is online now   Reply With Quote
Old 06-10-2015, 08:54 PM   #2
VinceU's Avatar
You didn't provide a open dimension but I've used large open S hooks or quick links rated for the load +.
VinceU is online now   Reply With Quote
Old 06-10-2015, 09:28 PM   #3
bulldog4949's Avatar
When I had my bumper pull with my '15 duramax I had to put the chains on from the back to the front.
2015 GMC 2500HD Duramax Denali
2015 XLR 300X12HP
2013 Polaris RZR 900 XP
bulldog4949 is offline   Reply With Quote
Old 06-10-2015, 09:31 PM   #4
asquared's Avatar
My 14 duramax 3500 had a narrower opening on the side of receiver I was able to hook my old tt chains to.
<a href= target=_blank></a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-10-2015, 09:48 PM   #5
Whatever you end up with, make sure your chains are long enough, or you'll end up doing this if you turn too sharply backing up:
Name:	Safety chain connection #2.jpg
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 06-11-2015, 08:51 AM   #6
jeff64's Avatar
You will have to go to your local hardware home center and get a couple large quick links. This is fairly common to do. I've had to do it with my F150 and my 2500HD
Old 06-11-2015, 09:08 AM   #7
Try comibg from top forward rather than bottoms back with hooks. They will fit.
CGO - A technical marketing data guru
Almost an owner of a 2014 Hemisphere 312QBUD
2011 Ford F-250 SD 6.7 Diesel
Texas outdoors by way of a PA farmboy.
ChiefGreedyOfficer is offline   Reply With Quote
Old 06-11-2015, 12:00 PM   #8
Had the same problem with my 2012 Silverado 2500 HD and my boat trailer. I just went to Lowes and purchased larger tow hooks.
offduty11 is offline   Reply With Quote
Old 06-12-2015, 06:31 AM   #9
As VinceU says, make sure that hooks, shackles, extra chain ... are rated for more than the load.
phf is online now   Reply With Quote
Old 06-12-2015, 06:46 AM   #10
muddyrode's Avatar
when i tow a trailer with my 2012 2500HD i use a small piece of chain to put thru the chain plates on the truck then hook my trailer safety chains to that i throw some black tape around the s hooks to keep them from falling apart
2012 wildcat sterling 32RL
2013 3500HD DRW Silverado Duramax
muddyrode is offline   Reply With Quote
500, safety
