06-14-2017, 05:08 PM
Hooking up anti sway
One of the bars go into place easily the other not so much.I was wondering if someone would have some ideas. It was put on by dealer
06-14-2017, 05:17 PM
Had the same problem with me e4. It took 2 of us to hook up the last time. Replaced it with a blue ox.
cliffy49
2018 Catalina Trail Blazer 26TH
2021 Chevy Silverado Custom 2500HD
06-14-2017, 05:39 PM
Is the truck and trailer sitting on the level when you try and hook up? If they are tilted then you will have different pressure side to side.
2017 Wolf Pup 17RP.
2014 F150 1/2 ton Larait.
Lots of motorcycles.
06-14-2017, 05:41 PM
Are you referring to load levelling arms, and not sway control? My sway control is 1sliding link, the load level is 2 bars/chains. Both go from hitch to tongue frame.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2020 Fuzion 369 toy hauler
06-14-2017, 08:05 PM
Thank you for input
06-14-2017, 08:10 PM
Ya from hitch to frame so that would be a leveler? make sense truck or trailer not level when connected
06-14-2017, 08:24 PM
When I have that problem after locking the hitch on the ball, I use the jack to raise it up enough to get the second side hitched. I have even had to pull the TT forward a couple of feet to make it easier. It is all about the angle.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
06-14-2017, 08:34 PM
Connect trailer to TV,latch coupler lock,Now with the Trailer Jack raise Both units "WAY Up",the Bars will easily go on the Brackets or Chains! Youroo!!
06-14-2017, 08:53 PM
X2, raise the tongue after you latch the coupler. The bars will slide right on.
Also, make sure to do the same when you unhitch. (raise the tongue to remove the force from the bars, remove the bars, lower tongue, unlatch the coupler)
2015 F-250 FX4
06-14-2017, 08:55 PM
This is the correct response. I have a power tongue jack so this is much easier. I raise it enough to be able to snap up the chain brackets by hand.
06-14-2017, 10:22 PM
To the OP, this is correct. Realize this is your load leveling bars, not the anti sway. Anti sway is a different device in most applications.
John
06-15-2017, 12:36 AM
KC, it would be helpful if you posted make and model of your WDH.
06-15-2017, 12:49 AM
x2 on both posts.
Raising the tongue jack will take the tension off and make inserting/removing the WDH bars much easier.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
06-15-2017, 09:48 AM
Thanks for the help . I do the lift thing but it is always the same side one goes on easy one is hard.Checked everything is mounted even must be the truck sitting uneven.Thanks everyone first post now you'll never shut me up.
06-15-2017, 12:23 PM
Newbie
KC, I have the same problem with my equalizer wdh. One side is usually easy, the other side I have to use the tool that came with the hitch to get it on or off. I've gotten used to it so it's not a big deal anymore. I need to invest in a power tongue jack though to make it easier.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
06-15-2017, 03:17 PM
Welcome to the forum. We are here to share and learn. Ask questions, also try using the search function too.
Back to your question, yes, I've got that too. I find when I grab my TT from storage, my truck sits a little uneven, and one is always harder to latch. And, thank the Good Lord I have a power jack. 1400+ lbs of tongue weight would kill me to lift it and the truck to get those spring bars on!
06-15-2017, 04:10 PM
Ditto!
