Old 04-11-2015, 07:37 PM   #11
lbrjet, That is good to know. Thanks for the response.
magpi26 is offline   Reply With Quote
Old 04-11-2015, 07:41 PM   #12
Scootdawg's Avatar
I down loaded the manual for your year and truck, and your trailer battery charge is relay 90 Enclosed are the pictures for the fuse and fuse box. My fuse box is located right in front of the engine when I open the hood. I found the fuse in my glove box. I hope this helps
ID:	73950   Click image for larger version
2014 F-150 SuperCrew
2015 Rockwood 8289WS Diamond
Scootdawg is offline   Reply With Quote
Old 04-11-2015, 07:41 PM   #13
dicky1243's Avatar
Originally Posted by Scorn View Post
I have a 2014 F150 Ecoboast 4 door Crew Cab with 3.73 axle, max tow, long bed, 11,100 lbs towing capacity and 1,100 tongue weight. 1677 payload, 15,400 CVWR,
Towing 2015 Heritage Glen 282RK, 6,786 dry wt, 675 tongue weight.
4 point Equalizer hitch with built in sway control.
When I read the title of the thread I figured that yoiu already knew that you were goning to compromise yours and everyone elses safety on the highway you are real close to having a 3500 instead. I hope this isn't a TT.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 04-11-2015, 07:53 PM   #14
"I have a 2014 F150 Ecoboast 4 door Crew Cab with 3.73 axle, max tow, long bed, 11,100 lbs towing capacity and 1,100 tongue weight. 1677 payload, 15,400 CVWR,
Towing 2015 Heritage Glen 282RK, 6,786 dry wt, 675 tongue weight."
How do you figure he's close to a 3500 towing well less than 10,000#
Old 04-11-2015, 09:00 PM   #15
Originally Posted by Scootdawg View Post
Love my 2014 ecoboost. Did you put the relay in the fuse box for battery charging? Page 225 of your owners manual shows u the position. My ford dealer (and most I heard) dont install the relay.
If he has the Max Tow package like he stated, the fuse is already there because it comes standard with the brake controller. The only time you have to add a fuse is if you don't have the Ford brake controller. In other words if you have to add a brake controller then you have to add the fuse.
Stovebolt is offline   Reply With Quote
Old 04-12-2015, 04:51 AM   #16
For your payload, remember to add the loaded trailer tongue weight, passenger and pet weight, fuel weight, and weight of anything else in the bed of the truck - generator, tools, bicycles, cooler, etc. Gasoline weighs approximately 6# per gallon.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 04-12-2015, 05:44 AM   #17
Gas 200 lbs, Passengers 350, tongue weight 850 (battery, propane) added, cargo 200 lbs total 1600 lbs. Close but with the weight distribution hitch I should be fine.
Scorn is offline   Reply With Quote
Old 04-12-2015, 06:49 AM   #18
Stormrider151's Avatar
Actually on the F150 Ford puts the fuse and relay in the glove box of the truck. I found this out when I took my trailer in for service and the battery was dead on the trailer. The tech new exactly what it was and installed them in about 2 minuets. He said they are all that way.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-12-2015, 07:39 AM   #19
Fuse
I remember when I bought my truck the salesman knew I was buying it to tow and he took the fuse out of my glove box and put it in for me.
Old 04-12-2015, 09:07 AM   #20
LANShark42's Avatar
There was a time I would have said I wouldn't try to tow much with an F150. Then I started reading about the Ecoboost Fords. I think I've changed my mind a bit...
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
truck
