Forest River Forums
Sunline User Photos
Old 09-28-2011, 10:44 AM   #1
(Kim)
Labzy's Avatar
How 'balanced' are our trailers?
With all the talk about TW's, axle weights, L&R side weights, it made me wonder 'how balanced are the trailers to begin with?'
How much engineering and work goes into designing the interiors of these units in regards to the placement of, well, everything?
There seems to be a big discrepancy in TWs between units, based on the location of storage, furniture, appliances etc, and its placement in regards to the axles, some being naturally inclined to put more weight in front, some in back......is there as big a difference between units for L&R or side to side weights?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
26 days booked for 2012 so far.......
Labzy is offline   Reply With Quote
Old 09-28-2011, 11:02 AM   #2
Moderator
mtnguy's Avatar
I feel pretty good about the balance of my trailer. The AC, fridge, and pantry are all pretty much inline with the axles. My fresh water tank is over the back axle, the grey directly in front of that, and the black tank in front of the grey. Coming back from picking it up from the dealer, I had a 13.5% tongue weight. Traveling now with the trailer loaded for camping, including ~1/4 tank of fresh water, I am at 12.8%. I do try to load the back heavy so that I can continue to use 800 lb. spring bars.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is online now   Reply With Quote
Old 09-28-2011, 11:17 AM   #3
(Kim)
Labzy's Avatar
The TW is easiest to 'fix' (via WDH) and easier to ascertain.
I do not however have access to a scale that will allow weighing my TT from R&L wheel/axle weights.
When I load my TT, I just assume that FR has tried to get it as balanced side-to-side as they can, and I just divide up my weight of cargo and put half on the R and half on the L.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 09-28-2011, 11:52 AM   #4
Moderator
mtnguy's Avatar
I weighed my side to side when I 1st got it, but can't find the information on that. I think is was something like only a 40 lb. difference.
2008 Surveyor 263
Old 09-28-2011, 01:04 PM   #5
I know that with our 2604 the right side of the trl is heavier then the left. The stove sink, and fridge are all on the right side. Also using a laser temp gage the right side tires are always about 15-20 degrees warmer then the left tires, with the exact same tire press on the left and right.
2008 Dakota Sport 4x4
2012 Rockwood 2604
2004 Subaru Baja - DW's go buggy
1970's Rupp Ruppster - my field go buggy at home
42 nights camping 2011, 2012 5 nights camped and 28 reserved
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-28-2011, 02:27 PM   #6
Moderator
acadianbob's Avatar
And I think my Surveyor is designed so that most of any additional weight will unfortunately go onto the tongue. So, I work real hard to shift as much to the back as possible; but options are limited.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
Old 09-28-2011, 03:07 PM   #7
camping
tentcamper1's Avatar
a lot better balanced than most of us on this forum!!
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 - 16
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 09-28-2011, 03:09 PM   #8
Moderator
TheSasks's Avatar
I think our V-Lite is pretty well balanced as it has all the appliances and toilette/ sink on the RH side and 2 slides on the LH side
John & Deb
2008 Dodge Ram 2500 4x4 Laramie Hemi Megacab
2011 Flagstaff V-Lite 30WRLS
TheSasks is offline   Reply With Quote
Old 09-28-2011, 05:22 PM   #9
flyrotor's Avatar
Left to right is not near as important as is center of gravity, hence, items that are mounted high in the trailer will affect handling more on the left to right axis when turning and braking, granted, actual weight left verses right needs to be in moderation.
Front to rear loading directly affects the handling as it places either more or less weight on the tow vehicle, such the need for WD hitches AND proper setup.
If you see the CG charts for aircraft for weight and balance this becomes more appearent.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 09-28-2011, 06:09 PM   #10
Yea if we all had flying campers
2012 Rockwood 2604
F.R.O.G. member
» Online Users: 596
109 members and 487 guests
1l243, 5Galvs, Adony, alphadog99, alpinemike, Andy R, autorot8, Bandit114, Barney1, bclemens, bob34787, bobbygee, boubou, brandon0214, brookside, Browndog, Cafjackracing, case1175, Chino63, chiro, chof16, CM BOXERS, comfun1, cyclepuck, dashonthedash, dasimser, Dave_at_FastwayTrailer, ddemme, dec1952, deerslayer, Dennis Carpenter, Deputyseven, DGrissom, djorgensen3, Dukejr, dummin4fun, dunnnc, electrician549, elind, frfan, gbpacker, Gizzerd, gjj, Gollum, Happy Vibe, HWII, Indy Steve, isz, itat, JamesR, jasni, jes520, JJones, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, Kevin-and-Julie, kfroe, kjoh75, leanne, LFugate, lochsa, Mad4sax, merlin66043, mesquiteguy, mhartzel, mia, Mr. Legato, mrmurph, mtnguy, pappcam, Pharmofish, PrairieBoy, punkaccountant, pwrplay, ret2006, rjshiflet, rkswyo, rodcop9405, Rogue69, ronhanson, Rsgtivr6, rstewart06, RV Guy, SabreMarv, SabreSam, Sailfish Bret, sbond, ses, snowbrid, spike, steeleshark2, Steve7575, texashatter, TheFlagGang5, Tincup13, tking1866, tmmar, toleworks, tomjsas, torben, viper48, wayne anthony, we2lovecamping, whj77372, Wichitalineman, woodchomper
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
