Thank you yes all that is good, my turn over ball/ gooseneck was installed by an truck accessory place and with the exception of the pull handle and the obvious holes in the bed was a “ bolt on” so pretty sure it is correct. The companion was installed by trl dealership I already swapped or flipped the pivot arms to go from way behind the pin to a lot closer the only other adjustment to be made is in what is the position of the drop shank from its current position of 1 or 2 too the position it’s not in.
However the cab is not in danger of being hit by the trailer I suspect/know moving up that my bumper will be very close but can say with some level of certainty that it won’t hit. but was curious about the distance between properly set up truck and mine because other than my daughter I don’t think anyone will fit between the truck and trl. The only problem with my last adjustment was cord was too short
