Old 06-06-2013, 10:42 PM   #1
How do I determine the necessary WDH capacity
We put a deposit on a Grey Wolf 28bhks I'm planning to tow with our 2012 5.0L F150 supercrew. Based on the forum it seems about as heavy a trailer (5200# Dry) as I'd want with the truck.
My question is with a dry tongue weight of 750 and a potential loaded tongue weight over 1000# do I need a 1200# hitch or is that overkill?
Thanks for the help
healeykit is offline   Reply With Quote
Old 06-06-2013, 11:10 PM   #2
jtstromsburg's Avatar
1200 is what you want for that camper. We had a 28bh, which is similar weights, and an e2 hitch with built in sway control pulling with a 1/2t burb. 1200 is what we had and it worked great.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 06-06-2013, 11:49 PM   #3
asquared's Avatar
My tt is similarly sized. I have 1200 lb bars as well. You want to determine the max tongue weight and go to the next size above it.... In this case you are looking at a max gvwr of 7700 lbs. 15% of 7700 lbs is 1155 lbs. You likely will never see that high of a tongue weight but it isn't impossible. 1200 lbs is next size up from 1155 lbs.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-07-2013, 05:37 AM   #4
Herk7769's Avatar
Thanks for the help
IMO, Go heavy (up to the hitch limit for your truck's receiver).
One day you might want to upgrade to a heavier camper/tow vehicle.
WD hitch's don't go bad... Mine is still in the shed (have a 5th wheel now) and use it occasionally. Never know when you might need to tow your brother's Backhoe to his farm.
HAM CALLSIGN - KC3FFW
