Old 02-02-2008, 11:44 AM   #11
jmyers's Avatar
hoorders, you answered my question before I even asked it. Excellent info.
My driver's license says my name is "Jeff"
2000 Chevy 2500 4/4 6.0/3.73
2002 FR Sandpiper 30FKSS
Reese Strait-Line
Prodigy
DW
DD (Darling Dachshund)
jmyers is offline   Reply With Quote
Old 02-03-2008, 08:09 AM   #12
No problemo!!!....
hoorders is offline   Reply With Quote
Old 02-03-2008, 03:47 PM   #13
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
That's the way my Nissan is. No overdrive switch, just TOW/HAUL switch that changes shift points.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 02-07-2008, 02:03 PM   #14
Dodge Guy's Avatar
Press once for tow/haul then if it still wants to "hunt" for gears press the T/H button a second time. this will turn off O/D and allow you to run in 3rd.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 02-15-2008, 03:12 PM   #15
I Have The Ford F-150 5.4 V8 And Tow With Od Off . Towing 9500 Lbs And It Does Just Great. Doesn't Loose Much Speed An Hills Either. It Is The Recommended Way When Towing Heavy Loads. Gas Mileage Not Really That Bad. Better To Be Safe Than Sorry. Towing In Od Could Burn Up Tranny Or Cost You Your Vacation. Read Your Owners Manual And It Should Tell You.
michael t cayouette is offline   Reply With Quote
Old 04-07-2008, 06:10 PM   #16
I have an 06 Ram Hemi Quad cab auto. 2whl. dr., and I HAD a coleman pop up. When towing this, I left the trans.in overdrive without any problems.
HOWEVER; I traded in my pop up on a 08 Flagstaff V-lite, 30 footer, and it needs the tow/haul mode to pull it, as it is MUCH heavier than the pop up. I figure it's about 6500 lbs. loaded. And I live in Florida. Just got back from a 400 miler, and overdrive would bog down the motor and slowly lose speed, until i switched back to tow/haul.
Old 04-07-2008, 09:40 PM   #17
The Jolly Mon
NDJollyMon's Avatar
tow/haul on
overdrive off
Pete (Jolly Mon)
