Old 01-30-2008, 11:35 PM   #1
Question How do I tow with O/D?
I have a 2005 Dodge Ram 1500 quad cab short bed 4x4 and I have been pulling utility trailers for 3 years now and am under the assumption that ANYTIME I am pulling something (no matter the weight) I need to push in the little "tow/haul" button on the end of the shifter. I assume this is turning overdrive off??
This info was given to my by the dealer service guys upon purchase of the truck. With the small utility trailer I noticed nothing, but with my new Flagstaff 831 KRSS I notice that the transmission shifts up and down a lot. The truck pulls fine as far as I can tell.
Could someone please explain how I want to operate my truck for towing to get the best results? I keep hearing o/d on unless... or 3rd gear for this situation and 2nd for that etc...
I just want to know the concept of how I need to pull to get the best performance. I am not a "gear head" so I don't know what is needed to get this done however, I do understand basic concepts of transmission etc...
Thanks, Frank
2005 Dodge Ram Quad Cab 4x4 (5.7L Hemi)
2008 Flagstaff 831 KRSS
2000 Son
2002 Daughter
1969 Wife
1974 Me
Live and Work in St. Louis, MO. area, but play everywhere!
fire4034 is offline   Reply With Quote
Old 01-30-2008, 11:52 PM   #2
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
When I tow with my Nissan, with a similar TOW/HAUL switch...
I towed my trailer with the button ON. It changes the shift points, and does away with a lot of that up/down shift. It also helps a lot starting/stopping. That constant up/down shift will heat up the tranny real fast...and we all know what happens then!
I'm not a gearhead either...but I always use the TOW/HAUL button, and downshifted one gear. (The Titan has a 5 speed tranny)
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 01-31-2008, 07:52 AM   #3
If you find your tranny shifting as you stated you need to manually shift to a lower gear, probably 3rd(?). If you don't you will overheat your tranny and then be stranded on the side of the road.
It sounds like you bought the truck new. Now is the time to "READ" the owners manual. Lots to learn in there, may even answer your question about the tow/haul mode.
JMHO...........
Paul B
2001 Excursion PSD
2000 CRV Honda
2006 829GRSS Flagstaff TT
2004 Twin 2000i Hondas'
Paul B is offline   Reply With Quote
Old 01-31-2008, 01:49 PM   #4
My dually has an overdrive on/off button probably serves the same as your tow/haul button. This is how I tow and is my opinion and observations only. Starting off and going through town where there are a lot of starts and stops I disengage the O/D. This keeps the transmission from shifting so much. On the highway once Iím up to speed 50-55mph I will re-engage the O/D so that the transmission shifts into the higher gear thereby increasing my fuel economy. On hills if I am loosing speed I will disengage the O/D to downshift the transmission to maintain speed. By disengaging the O/D going up hills it increases the RPM of the motor and keeps my EGTs (exhaust gas temperature) down as I have a diesel this is a concern.
aintgotnun is offline   Reply With Quote
Old 01-31-2008, 03:37 PM   #5
powerboatr's Avatar
my truck to has a tow/haul button
but it does not lock out OD or any other gear, it is a 5 speed as well, but in t/h it becomes a 6 speed by splitting one of the shift scenarios, its pretty neat. basicly locks the torque converter between 1-2 and creates a 1 1/2 gear
it does however
raise shift points, gives great engine braking when slowing down
my book says to use the t/h anytime a trailer is used.
i use it empty alot if i am in traffic as it raises the shift points but also limits the constant up shift and down shift stuff which created tons of heat.
i recommend what ever brand you have to read the onwers manual thoroughly.
i am sure ford, gm and dodge have pretty similiar programming in these newer trannies,
i also use cruise quite often pulling the rv, until we get in the mountains,
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 01-31-2008, 07:26 PM   #6
OK, so I read the owners manual, and they advise that you switch to OD on flat areas, and turn on the tow/haul switch (which turns off o/d) when you are on hills or notice a lot of shifting of the transmission.
Now for my question... It says also that if you notice a lot of shifting on hills you should downshift manually. I have 1 2 and D (I assume this is 1 2 and 3) so I am in 3 normally and I move down to 2nd on hills so the trans does not shift? So when you get to the top of the hill do you just shift back to D from 2nd while on the fly?
The manual said don't downshift above 5800rpm, but that is all they mentioned.
Frank
2000 Son
2002 Daughter
1969 Wife
1974 Me
Old 01-31-2008, 07:46 PM   #7
froglegs's Avatar
You need to engage the tow mode not the overdrive mode while towing. By doing this you don't have to worry about down shifting on hills and upshifting on level terrain. The trans will give resistance on the down hill grades and you will save your brake pads and be more attentative while driving. Relax and have fun-Life is short!!
2000 F-150 4x4 sc,off road pkg,Tow Pkg,5.4,3.73TL,2007 Flagstaff 8524RLS,and One Happy Maltese! See You Down The Road!!!
froglegs is offline   Reply With Quote
Old 01-31-2008, 09:03 PM   #8
Still not clear
I talked to the dealer via phone and I am going to talk to them when I am in for service etc... since one of his techs hauls a large trailer all the time with his truck and it is the same is mine.
I only have a tow/haul on the shifter, not familiar how to engage overdrive mode or tow mode as you describe it.
Thanks, Frank
2000 Son
2002 Daughter
1969 Wife
1974 Me
Old 02-01-2008, 08:21 PM   #9
budfans's Avatar
I agree with greg (aintgotnun ) normal terrain I leave it in over drive, when it gets hilly i'll turn the overdrive off
07 285B+ cherokee 5er
02 F350 power stroke c/c
budfans is offline   Reply With Quote
Old 02-02-2008, 12:32 PM   #10
The tow/haul (on_off) option is not the same as the O/D (on-off) option....the tow/haul mode changes shift paterns depending on the load on the truck.....in any event it will not let the tranny shift as early or as smoothly....it increases line pressure..........and you still have O/D with the tow/haul mode engaged.......it will very rarely go into O/D unless you are on very flat ground or down hill.
The O/D option simply disables O/D.
hoorders is offline   Reply With Quote
Old 02-02-2008, 12:44 PM   #11
jmyers's Avatar
hoorders, you answered my question before I even asked it. Excellent info.
My driver's license says my name is "Jeff"
2000 Chevy 2500 4/4 6.0/3.73
2002 FR Sandpiper 30FKSS
Reese Strait-Line
Prodigy
DW
DD (Darling Dachshund)
jmyers is offline   Reply With Quote
Old 02-03-2008, 09:09 AM   #12
No problemo!!!....
Old 02-03-2008, 04:47 PM   #13
The Jolly Mon
NDJollyMon's Avatar
That's the way my Nissan is. No overdrive switch, just TOW/HAUL switch that changes shift points.
Pete (Jolly Mon)
Old 02-07-2008, 03:03 PM   #14
Dodge Guy's Avatar
Press once for tow/haul then if it still wants to "hunt" for gears press the T/H button a second time. this will turn off O/D and allow you to run in 3rd.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 02-15-2008, 04:12 PM   #15
I Have The Ford F-150 5.4 V8 And Tow With Od Off . Towing 9500 Lbs And It Does Just Great. Doesn't Loose Much Speed An Hills Either. It Is The Recommended Way When Towing Heavy Loads. Gas Mileage Not Really That Bad. Better To Be Safe Than Sorry. Towing In Od Could Burn Up Tranny Or Cost You Your Vacation. Read Your Owners Manual And It Should Tell You.
michael t cayouette is offline   Reply With Quote
Old 04-07-2008, 06:10 PM   #16
I have an 06 Ram Hemi Quad cab auto. 2whl. dr., and I HAD a coleman pop up. When towing this, I left the trans.in overdrive without any problems.
HOWEVER; I traded in my pop up on a 08 Flagstaff V-lite, 30 footer, and it needs the tow/haul mode to pull it, as it is MUCH heavier than the pop up. I figure it's about 6500 lbs. loaded. And I live in Florida. Just got back from a 400 miler, and overdrive would bog down the motor and slowly lose speed, until i switched back to tow/haul.
Old 04-07-2008, 09:40 PM   #17
The Jolly Mon
NDJollyMon's Avatar
tow/haul on
overdrive off
Pete (Jolly Mon)
