Old 07-18-2015, 10:12 AM   #111
jlgail4309's Avatar
I got kumho 857 after one of the factory tire deformed. I just didn't like the thought of maxing the tire out at 65 all the time. Every time I would stop the cheap tires were so hot it would burn my hand. I wonder if maxing the st tires out at 65 could be the problem.
jlgail4309 is offline   Reply With Quote
Old 07-18-2015, 12:28 PM   #112
The lower the air pressure in the tire the hotter they will get. Max air pressure will keep them a lot cooler, that's why tires that are low on air blow out more often than those that are up to the air pressure required and also is the reason the auto manufacturers were forced to put tire monitoring in their cars due to the fact people never seem to be able to do proper maintenance on their own.
Stovebolt is offline   Reply With Quote
Old 07-18-2015, 01:52 PM   #113
Commercial Member
If your tires are too hot to hold your hand on them for about 5 seconds then YOU HAVE A PROBLEM
- Your pressure is too low for the load
and/or
- You are driving too fast or too close to a tire max speed rating
and/or
- Your tires are undersized for the actual load you carry
Re "deformed" tire. Have you captured a photo? Did you record the full DOT serial and have you filed a complaint with NHTSA?
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 07-18-2015, 09:06 PM   #114
jlgail4309's Avatar
Not sure the problem was with the factory tires. I put the Kumho 857 problem went away. Seems like it handles better with less bounce rides better. I did't take a picture or check the dot the trailer was almost new. I just thought the tires was cheapest they could put on the trailer . I read about all the blow outs and being a single axle. Blow out didn't sound good.
Old 07-18-2015, 09:46 PM   #115
dannyabear's Avatar
I couldn't get the Kumhos so i went with the Hankook RA08 On my 2703ws; much better, a true load range D, 8 ply, 99 mph rated and 2100# capacity. Whats not to like about them
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-19-2015, 06:53 AM   #116
jlgail4309's Avatar
I think the tire that are rated for the higher speed are a lot better. At least they are not maxed out on speed and load. It must me all about the money on new trailers. It a real problem on new trailers.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
Old 07-19-2015, 07:14 AM   #117
nomad297's Avatar
Originally Posted by Flybob View Post
X3 65
Carlisle makes ST tires rated for 75 mph.
Bruce
Old 07-19-2015, 08:43 AM   #118
Phat Phrog Stunt Crew
elind's Avatar
I max out my 16" E Westlakes at 80psi and when I temp them after stopping they're only at 105 degrees. I would guess that the lower pressure is going to create increased tire flex and greater heat.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 07-19-2015, 09:10 AM   #119
nomad297's Avatar
How about on those days when you're in Arizona and it's 110 degrees outside?
Bruce
Old 07-19-2015, 11:07 AM   #120
elind's Avatar
Bruce
Sure the temp will be higher seeing it was 70-80 degrees when I did the check. But it still will be cool enough to leave my hand on it at Arizona temps.
2014 Wildcat 327ck
