Old 07-18-2016, 08:19 AM   #1
How level
Just purchased my FIRST FW - pulling it with a 2016 Chev. 2500 HD 6.5'
bed. Wondering how level must the FW be when attached to the truck ?
ksmith954 is offline   Reply With Quote
Old 07-18-2016, 09:36 AM   #2
It depends on your hitch. Some will tilt (left/right) quite a bit but you bed rails need to clear too.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 07-18-2016, 09:41 AM   #3
The FW is about 1" high and the rail clearance is 5 1/2 " to 6"
Old 07-18-2016, 09:45 AM   #4
Typically you would want to be a little closer to level I think, but doesn't sound like you should mess with it due to being at the lower end of desirable rail clearance.
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
mikeysotp is offline   Reply With Quote
Old 07-18-2016, 10:09 AM   #5
NMWildcat's Avatar
I say anything within an inch is good, unless you have towing problems. I worry more about rail clearance and you are at the minimum.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 07-18-2016, 10:20 AM   #6
Frog-Toberfest Organizer
Just watch the rails on tight turns. My hitch was a little low and I hit the side rial on a tight turn in a campground.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
Electra glide is offline   Reply With Quote
Old 07-18-2016, 10:44 AM   #7
1" high in the front isn't a problem.
5-1/2"- 6" of rail clearance shouldn't be either unless you get into some serious uneven terrain.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-19-2016, 03:16 PM   #8
One inch is a little high. There are adjustments in many 5th wheel hitch's and pin boxes.
I would try to get it level. Good Luck
whj77372 is offline   Reply With Quote
Old 07-19-2016, 05:31 PM   #9
Do you mean your trailer is 1 inch higher in the fron than the rear? If so, I wouldn't worry about it.
Steve29rlx is offline   Reply With Quote
Old 07-19-2016, 06:15 PM   #10
Yeah, chasing 1" is silly. An extra case of beer will change that! (I am of course exaggerating to make a point. Your load will affect things... and chasing after 1" will just drive you crazy.)
A 1" difference between the front and rear means around 1/2" change at one end... because lowering one end raises the other end at the same time. And vice versa.
You also have to make sure you are on a 100% flat surface. If not, minor variations can give you your 1". The closer you get to level, that last little bit becomes futile. The next time you hitch up and measure, it will be different!
All of this is not to say run obviously high or low. Just trying to say, after a certain point, close really is good enough.
325BH is offline   Reply With Quote
Old 07-19-2016, 07:27 PM   #11
I don't have anymore simple adjustments to make- Dropping the hitch I lose my 6" rail clearance( can barely get in driveway) and the Revolution pin box is not adjustable and I already have 16" maxis tires on it. The one small trip I've taken- it pulls super. I have plenty of pin weight left so maybe I'll pack a few more items up front. All these newer 3/4 ton trucks sit high- maybe I'm fortunate to only to be 1" high in the front of the FW. ? Just so new to a FW not sure of the limits.
I really appreciate the input of all you savvy veterans !
Old 07-19-2016, 08:06 PM   #12
NMWildcat's Avatar
Ah, I understand better now. I don't have the revolution but I do have a sidewinder. They do tend to hang lower than a standard kingpin box. I have my hitch in the truck lowered as far as it will go and the sidewinder raised as high as it will go and I'm still an inch high in front. Add your newer truck bed being higher and I'm surprised you are only an inch high! Sounds like you are good to go. Have fun!!!!
