Old 07-12-2012, 12:00 PM   #91
mstell2's Avatar
I got 17 inch rims and 10 ply tires.
mstell2 is offline   Reply With Quote
Old 07-12-2012, 06:53 PM   #92
Brigitte
boubou's Avatar
Originally Posted by Rugged Brown
I vote for the Timbrens. Keeps the truck level under load and maintenance free. No compressors. Just install and forget. No noticeable difference in ride when not connected to 5er.
Hitched 5W with Timbrens installed. Much better. Instead of the (gasp!!!!) 4 inch sag I got without them, the truck is down 2 inches on the back. Acceptable?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 07-12-2012, 07:47 PM   #93
Air bags will give you the full 4" back.
Old 07-12-2012, 07:58 PM   #94
Brigitte
boubou's Avatar
Don't like the maintenance of it so if I can get away with the timbrens it would be better.
2 inch sag too much? I measured from top of rearwell to bottom of wheel before and after. Is that the correct procedure?
Superglide 2700
Timbrens
Old 07-12-2012, 08:02 PM   #95
[QUOTE=boubou;221847]Don't like the maintenance of it so if I can get away with the timbrens it would be better...QUOTE]
Don't know what maintenance there is, have had this set on 3 trucks in 17 yrs and have never done anything but push a button to add air or another button to release air, but, to each his own.
Old 07-12-2012, 08:09 PM   #96
Brigitte
boubou's Avatar
Live in Canada, some winters are harsher than others. Was told that snow and ice can be hard on the air lines... We'll see...
Superglide 2700
Timbrens
Old 07-12-2012, 08:15 PM   #97
Only if the installer leaves them hanging and the ice/snow hangs on them. Mine are anchored so that can't happen. I raised hell with the installer and he did as I told him. (I was the installer)
Old 07-12-2012, 09:27 PM   #98
Rugged Brown's Avatar
[QUOTE=dunnnc;221849]
I read some where on this forum about pin holes. Lines getting kinked and so on. Sounds like maintenance to me. And to have to keep pushing buttons to change air pressure. That's almost as arduous a task as changing TV channels with a remote. Sounds too much like work for me. I like it more simple.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 07-12-2012, 09:40 PM   #99
[QUOTE=Rugged Brown;221916]
Do you have DW work the remote for you?
Who decides what channel or is that too arduous also.
Old 07-13-2012, 09:31 AM   #100
Brigitte
boubou's Avatar
Measured wrong. Before timbrens, 3.5 inch sag and with timbrens, 1.5 inches
Superglide 2700
Timbrens
