Old 06-01-2014, 06:45 PM   #221
MikeInRaleigh's Avatar
ST, I went through the same analysis last fall and ended up with an F350 pretty much exactly like yours. However, I do think the payload number on the F250 is an artificial limit driven by marketing rather than technical aspects. I understand that anyone using a truck in interstate commerce is subject to commercial driver license and rules if the truck has GVWR of greater than 10,000 lbs., and I'm guessing a large part of Fords target market for F250 is commercial. I've been through all the technical specs for axles, tires, springs, etc. and there is no apparent technical reason for there to be 1500 lbs. difference in the payload rating of F250 Vs. F350. However, to avoid any legal exposures due to "overloading" according to the nameplate, I went ahead and got the F350 as well. This did create a different problem for me, as it is now impossible to level my trailer when towing, because the bed is so high on the truck, and I have torsion axles on my Rockwood. Fortunately I have enough excess capacity on the trailer axles and tires, that even with the extra weight on the rear tires due to the out of level, I am still below the load specs, and it tows just fine. Also, I've checked the tire temperature and pressure rise when travelling and haven't seen any significant difference in front and rear tires.
2010 Rockwood 8280WS Fifth Wheel
2013 F350 Crew Cab SRW, Standard Bed PS Diesel
Reese Airborne Pin Box, Reese 16K Manual Slider.
Camped 36 Days in 2012, 23 Days in 2013, 35 Days in 2014, 30 Days in 2015, 46 Days in 2016, 5 days in 2017.
MikeInRaleigh is offline   Reply With Quote
Old 06-01-2014, 06:50 PM   #222
MikeInRaleigh, You can put a riser kit on the trailer. How much does the trailer need to be raised?
Have you considered longer rear shackles on the truck to lower it? I did on my 1/2T because I don't like to see it "running downhill".
Old 06-01-2014, 06:53 PM   #223
dannyabear's Avatar
Cheaper/easier to remove the spacer block between the axle housing and springs on the truck
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 06-02-2014, 12:34 AM   #224
mstell2's Avatar
I put a riser kit on my Rockwood fifth wheel and that was the best $150 I ever spent. Now camper sits level on my truck.
mstell2 is offline   Reply With Quote
Old 06-02-2014, 06:00 PM   #225
Jammer3025's Avatar
Last trip to San Diego, we say a Toyota Tacoma with at least a 30 ft fifth wheel. I thought that was crazy. I should have taken a picture.
2017 Salem 32bhds
2015 Ram 3500 DRW, CTD 4x4, MC,Aisin,4.10's
SIX BURNIN - SIX TURNIN
Jammer3025 is offline   Reply With Quote
Old 06-02-2014, 06:23 PM   #226
Not a Toyota, but still a 1/2T.
Name:	05 Silverado 1500 with 2012 Flagstaff 8528RKWS (2).jpg
Old 06-02-2014, 06:29 PM   #227
Thats not that bad. Here is my former rig, and I was within all the ratings. Of course mine was a heavy payload F150...
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 06-02-2014, 06:32 PM   #228
Ret E-9 Anchor-clanker
donanddona's Avatar
Yes 1/2ton with my 5th wheel. Five years now. Drive train serviced every other year, differential and tranny flushed. Still going....
Name:	Shady Creek.jpg
donanddona is offline   Reply With Quote
Old 06-02-2014, 06:32 PM   #229
looking good OC
___________________________________
Salmon Hunter
2011 Crusader 320 RLT/ Honda 3000ei
2006 Chevy 2500HD 4x4 Crew Cab/Duramax Diesel/Allison Transmission
Salmon Hunter is offline   Reply With Quote
Old 06-03-2014, 08:12 AM   #230
Fulltime family RVer
Tacoma or Tundra? There's a big difference in those 2...
