Old 07-06-2012, 08:14 PM   #41
Originally Posted by pwrstroke2012 View Post
BouBou, alot of difference of what is safer and what is safe. As I said, it is what you are comfortable with.
Please explain what the difference is.
Old 07-06-2012, 08:38 PM   #42
transamz9's Avatar
Most people would say that a F450 pulling a 8,000# fiver would be safe, but you are always going to some more experienced person that is going to say it would be safer to pull it with a Peterbilt 379.
I say run the numbers and if you are with-in them and as long as YOU feel comfortable pulling it then it's safe. A problem can happen with any TV large or small.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 07-06-2012, 08:49 PM   #43
I was ready to upgrade to a 3/4 ton until I tried the Tundra 5.7. Best towing vehicle I've ever driven.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
Old 07-06-2012, 08:51 PM   #44
transamz9's Avatar
2006 EZ GO 6" lift
Old 07-06-2012, 09:33 PM   #45
On the Dodge Ram the difference between a 1500 and 2500 chassis is significant. First off the frames are completly different have a look at a frame rail on a 1500 then a 2500 and you tell me wich looks stronger. The rear axle is much larger not to mention there is no solid front axle in a 1500 it's an aluminum housing with half shafts and torsion bars. The brakes are not even in the same league calipers on a 2500 are gigantic. The motors (if gas is the choice in the 2500) are the shared component and as stated power is rarley the limiting factor.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 07-06-2012, 10:17 PM   #46
Thank you Transamz, that is all I was trying to say.
pwrstroke2012 is offline   Reply With Quote
Old 07-07-2012, 06:32 AM   #47
dretired's Avatar
ID:	16190 This post began as" whos towing a 5ver with a 1/2 ton truck" Most everyone would agree a 3/4 or 1 ton would be better..load capacity... towing capability..future upgrade in weight of a 5ver could be possible... with a 2500 or 3500 truck...but....this post was about those of us that have 1/2 tons ..NOT the others
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 07-07-2012, 07:24 AM   #48
A lot of people tow more than their 1/2 capacities say they should, but their are a lot of 3/4 tons that exceed their capacities as well. I would hazard a guess that 75% of people who tow RV's don't have a clue what their weights really are.
Len & Cheri is offline   Reply With Quote
Old 07-07-2012, 10:26 AM   #49
Brigitte
boubou's Avatar
Agreed! I am convinced that most people just go out and and purchase a TT or 5W with just the TV's manufacturer specs and the TT or 5W dry or If they are really keen about it, the yellow sticker. Most probably don't even think about weighing their rigs. So, yes, I'll bet there are a lot more 3/4 ton over the limits than half ton but they on the other hand don't get questioned, some people just assume that because they own a 3/4 ton truck they can tow anything.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 07-07-2012, 10:28 AM   #50
Brigitte
boubou's Avatar
Yep! I was looking for people's feedbacks based on their personal experience on towing 5W with half ton. Great tread and lots of info
Superglide 2700
Timbrens
