Old 06-05-2019, 10:43 AM   #1
How much does your tongue weight change?
Bought a Sherline tongue weight scale to figure out my tongue weight. Took it multiple times. I was around 750 pounds "Semi Loaded" GTW is 7687... I can't imagine me adding much more weight. Maybe a couple hundred pounds near the axles and towards the front of the trailer to get to that 10-15%. Any advice?
Basically my question is, if anyone has actually gotten their tongue weight loaded and unloaded and how much it changed. Our trip is coming up fast and I might have to take the weight under the jack vs. under the tongue like I did the first time.
2017 Chevy Silverado 1500 LT/Z71/4X4/3.42 gears
2019 Palomino Puma 27RBQC
Infinite_Enigma32 is offline   Reply With Quote
Old 06-05-2019, 08:23 PM   #2
Sham183
mopwr4me2003's Avatar
You need to get a actual weight of your trailer to determine what you need at the tongue for weight. Even with the numbers you have you are under the minimum that is recommended of 10%. You should be between 10-15% of your total weight of the trailer. So if you were to be very generic in your weights and went off the GVWR of your TT of 7687 you would need a minimum of 768#. Donít guess at your weights you could end up having issues that you may not be able to control. My suggestion is if you have it loaded take it to the scales and weigh everything and go from there. Just not enough info to make a sure suggestion to you. Good luck.
Tim
mopwr4me2003 is offline   Reply With Quote
Old 06-05-2019, 08:33 PM   #3
bikendan's Avatar
My TT has a brochure dry tongue weight of 620lbs.
Weighed on my Sherline, it was 750lbs, with only basic stuff in the trailer.
Equalizer WDH
Old 06-05-2019, 08:40 PM   #4
dannyabear's Avatar
$10 to weight at almost any truckstop
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 06-05-2019, 09:55 PM   #5
Go West's Avatar
"Advertised": Brochure for my Grey Wolf 25RL lists the unloaded vehicle weight as 4,777 lbs and dry hitch weight as 633 lbs (tongue weight = 13.3% of UVW).
"Actual": CAT Scale says the trailer weighs 5,220 lbs loaded on the road. Sherline scale says hitch weight is 760 lbs (tongue weight = 14.6% of loaded trailer weight).
Name:	Sherline Hitch Weight - Grey Wolf 25RL.jpg
________________________
2017 Cherokee Grey Wolf 25RL
2017 Nissan Titan SV 4x4
Husky Centerline TS
Go West is offline   Reply With Quote
Old 06-06-2019, 05:11 AM   #6
BigH's Avatar
I check the tongue weight every pull. The sticker on the side of my trailer listed the tongue weight just under 1000lbs empty. I have seen up to 1500lbs. My trailer is a toyhauler and the load varies considerably with how it gets loaded.
You say 'semi loaded' and then give the trailer's GTW...the actual amount of load makes a difference...are you at 6700lbs or 7700lbs? If you are anywhere close to the upper number I would be concerned enough to increase the tongue weight before pulling by moving some stuff to the forward end of the trailer. -Be mindful of your truck's payload.
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 06-06-2019, 09:20 AM   #7
Thanks for the replies. I won't ever be close to the actual GTW. We never fill the FWT, have a handful of camping chairs, a table top Coleman Stove, food for 4-5 days... I know it adds up fast, but can't imagine even touching the top weight. My plan is to load it completely for the trip and take the tongue weight and go to a CAT scale that's right down the road. If my numbers aren't close, I'll rearrange before starting the trip. Was just curious how much of a change you noticed if you do check your tongue weight.
Old 06-06-2019, 07:41 PM   #8
Huge difference
I could make a huge difference by simply moving my two toolboxes from the tow vehicle to the front of the travel trailer. One's 40 lbs and the other is 50.
Larry
(Call me a fanatic but I like to have tools for any eventuality.)
Larry-NC is offline   Reply With Quote
Old 06-07-2019, 11:46 AM   #9
My rear axle weight was 3240 w/o trailer and full gas tank(34 gal). With trailer and full gas it was 4980. With trailer and gas 1/4 full it was 4580. Amount of gas makes a big difference on drive wheels even tho togue loading from trailer would not change, so what is more important tongue load or drive wheel load?
AdamKam is offline   Reply With Quote
Old 06-07-2019, 12:50 PM   #10
Just as confused as you
Scrapper's Avatar
Those numbers don't look right. 1 gallon of gasoline weighs 6.217 lbs, round that up to 6.5 for variation between blends. Your saying that 165.75 lbs of gasoline adds 400 lbs to your rear axle weight?
gallon of gasoline = 6.217lbs, gallon of diesel fuel = 6.943lbs, gallon of water = 8.3lbs
34gal x 6.5 = 221 lbs
221 x .75 = 165.75 lbs
RAW with trailer and 34 gallons of gas = 4980 lbs
RAW with trailer and 8.5 gallons of gas = 4580 lbs
4980 - 4580 = 400 lbs
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 06-07-2019, 01:09 PM   #11
I agree with your numbers, but that is the numbers based on my TV fuel guage. The only other variable would be the fresh water tank reading which is not very accurate. My only question is which is most important, drive axle weight or tongue weight?
Old 06-07-2019, 01:22 PM   #12
One other thing I noticed that the trailer axle weight went from 8940 with full tank to8800 with 1/4 full tank. I don't know the accuracy of the scales, although these weights were from the same Loves location..
tongue weight, weight
