How much weight does a WD hitch actually distribute?
Let's assume a loaded tongue weight of 1,000 lbs and an Equalizer 1,000/10,000 WD hitch. I realize the way it's set up will determine how much of the 1,000 lbs will get transferred to the TV front axle and trailer rear axle, but does anyone know the range of what percentage of the tongue weight can be distributed? For example, can 50% (500 lbs) or 60% (600 lbs) or even more be moved off the tongue?
Dave
2019 Columbus 366RL-1492
2014 Ram 3500 CC 4x4 SRW SB Cummins
Short answer, I don't think you can distribute that much weight off of the tongue unless you put too much weight on the steering axle.
I have redistributed 17% of my 680 lb. tongue weight off of the tongue, and that is with 40 lbs added to my steering axle over a truck with no trailer.
I am adding 320 lbs to my steering axle (trailer with no WDH vs. with WDH), and adding 140 lbs. to my trailer axle. Geez, that should be 460 lbs., right ?? But.......I am taking that weight off of the rear truck axle (trailer with no WDH vs. with WDH).
Figure 15-20% of the TW will be moved to the trailer axles and 0% to the front axle of the truck. Set up correctly the front axle of the truck should weigh the same (or close) hitched and unhitched.
Putting the trailer on the truck removes weight from the front axle and adds it to the rear axle. Then when you hook up the W/D hitch the same (removed) weight is transferred back to the front axle.
I do not think that is entirely true given when you setup a WD hitch by the book and measure front and rear fender height prior to hitching up the trailer and then after, your goal is to have the same ratio after as you had at the start. IE if you had 6" tire to fender all around before and after the rear was at 5" the front should be close to 5" as well, allowing the rear to sit abit lower than the front. That being said the front axle has taken on additional weight as well just not as much as the rear axle or it wouldn't be sitting lower than when you started. This is required given most front axles are not rated as high as the rears case being our megacab has a front GAWR of 5200lbs and a rear GAWR of 6010lbs so the bias should always be slightly to the rear. There are many sites out there that have the proper methods of setting up a hitch and all would seem to indicate the front axle does indeed weigh more after a proper WD setup.
John & Deb
2011 Flagstaff V-Lite 30WRLS
I respectfully disagree. Look at the owners manual W/D hitch instructions from any of the big three current model trucks or a hitch manufacture like Equalizer. Things have changed in these set up instructions over the past several years. There is a ton of info on this over at rv.net. I agree that it used to be as you described, but not anymore.
As I understand it you are only limited by the strength of the tension bars. Shifting load from the rear axle results in approximately the same shift in the front (300 off the rear adds 300 lbs to the front versus no wd hitch). In addition theory would add about 600 to the trailer axle(s).
This is of course theory. In actuality it never happens so evenly, but ideally you'll get close to what the math would dictate.
The tongue weight does not change however. The redistribution of the weight happens due to the torsion forces applied to the shank of the wd hitch system, effectively creating up force at the receiver to cancel out some of the dead weight, thereby shifting weight off the rear axle of the tv allowing ,more weight to fall on the front axle of the tv. The spring bars create up force on the aframe of the trailer and part of the force transfers to the trailer axles.
There is a good summary of the thread in the first post along with diagrams and all the math if you are into statics.
Keep in mind however that if you tension your bars (or have bars too heavy for your trailer) and end up with less weight on your tv rear axle and more weight on you tv front axle that you will have poor and unsafe handling.
My limited understanding of the dynamics of the WD hitch is that the dead tongue weight (the weight you would weigh if you put a scale under the front caster) is distributed onto all four wheels of the TV and the camper's axles such that the truck will ride level.
With a load on the rear bumper lacking a WD hitch (just a ball); and the bumper is located say 2 feet from the rear axle; it will tend to lift the front of the truck and depress the rear. Like a teeter-totter with the rear axle as the fulcrum.
The WD bars take some of that dead load and "distribute it" forward to the front axle of the TV and the camper's axles. The amount of weight transferred to the front depends on the tension in the bars. The shorter the links the more tension and the more weight on the front axle. The longer the links, the less weight is transferred and it stays on the rear axle.
The goal is to have just enough tension for the front and rear axles to ride in the same level attitude it did before the trailer was attached. Chap said it best in his post that covered the whole thing including the weights of his actual truck! Great job BTW.
From the manual:
Weight Distribution:
Weight distribution is the ability of a hitch to transfer some of the tongue
weight of the trailer ahead to the tow vehicle axles, and backward to the
trailer axles. Without weight distribution the tow vehicle “teeter-totters” on the rear axle of the tow vehicle, and unweights the front axle. Proper weight distribution transfers weight back to the front steering axle, forcing it back to the ground.
Proper weight distribution also adds performance to the integrated sway
control feature of your Equal-i-zer® hitch. The Equal-i-zer hitch requires a
minimum tongue weight of at least 10% of gross trailer weight.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Thank you all for your replies and helpful links. Looks like I have some reading to do.
The issue behind the question is that I'm within a few weeks of taking delivery on a 2012 V-Lite 30WFKSS. I'm comfortable that I'll be under the GCWR of my 2009 Dodge 1500 4x4 w/3:92 (GCWR 15,500; confirmed via email from Dodge Body Builder). But I'm getting concerned that the tongue weight when loaded could be 1,000 lbs or greater ... and after allowing for driver, passenger, 32 gal of fuel and some cargo in the pick-up bed, I could end up approx 600 lbs over GVWR (6,800) and approx 100 lbs over the rear GAWR (3,900). Needless to say, I'm hoping there's a way to set up my Equalizer 1k/10k hitch to transfer as much weight as possible back to the trailer axles.
I noticed a few other members pull the same model trailer with 1/2 ton trucks. Any thoughts/suggestions/comments?
Dave
You are beginning to understand by observing first hand the limitations of the 1/2 ton series of tow vehicles. Since the motor, trans and rear determine "tow rating" and "Gross Combined weight" you can easily be talked into less truck than required (since most dealers order lots of those and have them on the lot). 3/4 ton series trucks (configured for towing) are a rare breed and most need to be special ordered.
So since you have plenty of engine and gears, you can easily pull your trailer with the truck you have. At issue is the weight your truck can "carry" on its back without hurting it.
Just like a human back, repetitive stress can throw out your back. Typically, it is never a "one and done" event. The day you throw out your back or blow a disc, you are most likely not maxing out your back. You are doing what you always did maybe even less. Just "today was the day" it all caught up to you.
Many folks overload their trucks routinely and never have a problem. They either trade trucks often or wreck them in traffic or a dozen other reasons for giving an over worked truck to someone else.
If they do happen to break a spring or axle or GFB crack a frame, you never hear about it on forums like this one. There are lots of over worked trucks on used car lots with frame issues of all series due to abuse. Spotting a cracked frame is difficult without a lift and most get sold to folks who will never have more than a few hundred pounds in them anyway.
If you are not planning on keeping the truck and only tow infrequently, you may very well be one of the "Happy Campers" who tow over their rating. If you plan on "Full Timing" or camp a lot you most likely should plan on an early trade up to a heavier vehicle IMO.
From the Reese round bar installation guide "Lower jack. Re-measure front and rear wheel well reference points (vehicle should settle evenly, within about 1/2inch)." Isn't that saying that the weight added to the TV is evenly distributed over both axles. I could be confused, but I see that meaning if you add 1000 lbs tongue weight then approx. 500 lbs will be added to each axle, or adding enough weight to settle the TV evenly.
There might different instructions on setup somewhere, but I found that one on the Reese site. I'm going to be re-doing my setup soon and if there are better instructions please let me know.
I was wondering where the actual weight of the WDH itself adds in?
My Reece set-up weighs about 70lbs.
Without being connected, the entire weight is on the truck.
However, just like every other pound of truck and camper, with a WD hitch in use, it is "shared" amongst the combination based on the tension in the WD hitch. Most is on the truck through.
True.
In order to re-distribute the weight, the weight has to be there in the first place.
Many TT dealers try and 'up-sell' by saying that the WDH will take the weight off the hitch completely and make it somehow, magically disappear.
Now, you have room to tow something even BIGGER.
( I wonder where they keep their magic wands......??)
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
True.
They keep it right next to the "Pixie Dust" they sprinkle on your wallet to make twenties disappear when you walk by the service department.
I agree Herk though overloading of the tow vehicle is not unique to 1/2 T's...lots of overloaded 3/4 T's, particularly towing 5th wheels.
Dave
Dave, not to hijack the thread, but you are quite correct. I actually have seen more overloaded 2500 series trucks than 1500 series trucks in my travels. Anyone towing a 15,000 pound camper on their 2500 is seriously overloaded. 20% pin weight on a 15,000 pound camper is 3000 pound pin.
Not many have that payload available after mom and the kids and hitch are added.
With all the "must have" junk I carry around in the truck bed of my Sierra 2500HD Duramax diesel with Allison Transmission (max tow "rating" 15,300 pounds), my truck's GVWR (9200 pounds) is maxed out with my 9100 pound Flagstaff 5th wheel on it's back.
So I finally had some time to read a bunch of the info you all provided. Thanks again for your very thoughtful and informative responses!!
It appears that the answer to my original question is the WD hitch could provide an opportunity to move approx 6% (60 lbs) of trailer tongue weight (1,000 lbs) to the truck front axle and another 20% (200 lbs) to the trailer axles.
So the good news is that instead of being approx 100 lbs overweight on my rear axle (per my second post), I could possibly end up below my rear GAWR by approx 160 lbs. But the bad news is that I'll still be over my TV's GVWR by approx 400 lbs (instead of 600 lbs).
Am I on the right track here?
Dave
Dave
Dave
Again I have to emphasize that the amount of tension on the bars determines the actual amount of weight distributed. There is NO way anyone can make a statement like that without weighing the rig twice for each tension setting tried. Once without the bars under tension and then again for each tension step (on the Equalizer type hitch) or chain link (on the types that use chain).
Theoretically, (though not possible in reality) enough tension applied to the distribution bars could actually transfer all the rear axle weight to the front and camper axles, effectively letting you remove the rear wheels all together. Your WD system would have to be capable of handling the rear axle load of thousands of pounds; not hundreds; but the principle is the same.
Andy (Jeep4Two)'s post link has an excellent explanation of how this all works.
I quote from the summation at the bottom:
"It is interesting to note that TT weight and “tongue weight” do not enter into these calculations. The WD hitch does not distribute “tongue weight”. It simply removes load from the TV’s rear axle and distributes it to the TV’s front axle and the TT’s axles."
The amount of load that can be "distributed" and where it goes is determined by the WD hitch capacity and the distance between the hitch head and the truck front and camper rear axles.
Thanks Herk for sticking with me here and setting me straight. I went back to the link in Andy's post (thanks again Andy) and see that I have more homework to do.
In the meantime, I took my TV - with full gas tank, passengers, Equalizer hitch in the receiver and typical camping cargo in the bed - to the CAT scale in order to know exactly what I'm working with. The weights are: Front Axle 3,520; Rear Axle 3,020; Gross Weight 6,540.
At this point I'm comfortable that with the new trailer (loaded 8,300; tongue 1,000) and a properly set up WD hitch moving some weight off the TV to the TT, I should be ok with axle weights (GAWR 3,900 front and rear) and combined weight (GCWR 15,500). The only problem area I see is the TV weight.
With WD disconnected the GVW (TV + tongue weight) will be 7,540 lbs. With WD connected it will be something less than 7,540, but still greater than the TV's GVWR of 6,800 lbs.
Does any of this make sense?
Dave
