02-09-2016, 09:23 AM
How often to change transmission fluid?
For the newer Ford diesels with the 6 speed auto transmission that is used 75% towing heavy fiver, when should transmission fluid be changed? The Ford maintenance guide only says to change it at 150,000 miles. It does not differentiate between towing or not. I've always believed that when towing heavy, transmission fluid life is shortened due mostly to higher operating temperatures, and oil shear. So, what are others doing?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
02-09-2016, 09:28 AM
Who Dares, Wins
Does the manual address tough service? My Chevy manual give general service and rough service recommendations.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
02-09-2016, 09:29 AM
Unless your a Very Lucky person I would change before 150.000 miles! Youroo!! Most MFG have a "Severe Use" section,which Heavy Towing falls under!
02-09-2016, 09:37 AM
Who Dares, Wins
I just looked at mine for comparison.. 97,500(odd number) for standard duty, 45,000 for severe duty.. Again on a Chevy diesel, but I'd guess for cannot be to do far off. Odd part, my gas Manuel said nothing about transmission fluid changes on standard use, only severe usage at 45,000 as well.
2015 Chevy HD D-Max
02-09-2016, 09:40 AM
Even if you change your transmission fluid every 40-45K miles like I do, you still will not get much more than 400K out of your auto transmission.
Take care of your transmission. It is the weak link in the drive train.
2016 Jayco Eagle 330RSTS = " Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = " Hagrid"
360 degree Virtual Tour
02-09-2016, 09:42 AM
Who Dares, Wins
Originally Posted by Fairenatic
Even if you change your transmission fluid every 40-45K miles like I do, you will not get much more than 400K out of your auto transmission.
Ok, thanks, I guess
400k miles ain't half bad in my book.. I'll be happy if I make it to that...
2015 Chevy HD D-Max
02-09-2016, 09:44 AM
Ok, thanks, I guess
I have never found anyone to rebuild an Aisin transmission. They run around $7000 new.
02-09-2016, 09:46 AM
How many RV tow vehicles have you had for you to have Data that "400.000 Miles"? Youroo!!
02-09-2016, 09:51 AM
Let me see, I buy a new one about every 5 years and I have been towing trailers for over 25 years, so that makes about 5 or 6.
02-09-2016, 10:00 AM
Oh I see you are a Transporter that puts 400.000 miles on your Truck in 5 years! Boy not much time to Camp! Youroo!!
02-09-2016, 10:03 AM
I am a Turbo Machinery expert and control systems engineer. I travel to all the plants across the country for start ups, repairs, process automation, instrumentation upgrades, and safety system audits.
Yes, lots of miles. But I always make time to see the sites along the way. Been in every state except Hawaii, at least once.
02-09-2016, 10:16 AM
Who Dares, Wins
We are WAY OFF TOPIC HERE... But you said Aisin trans, that's Dodge (I think not a ram guy) my guess was you meant Allison(chevy trans)?
2015 Chevy HD D-Max
02-09-2016, 10:23 AM
GLCM Warrior
I agree the owner's manual calls for a transmission fluid change at 150k miles regardless of vehicle use. The new transmission does use a synthetic transmission fluid so I'd expect some extended life but 150k seems like a lot considering that on my F250 the specified interval when towing was 30k.
50k would seem more reasonable to me, but maybe synthetic tranny fluid is that good?
Since I typically follow the maintenance requirements as called out in the owner's manuals, I'll likely just keep an eye on the fluid level & condition and make my decision as the fluid ages. However, I'm sure the local Ford dealership will press for a fluid change long before we reach 150k.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
02-09-2016, 10:55 AM
My GM dealer said 45,000 miles since I tow a heavy trailer, I think they wanted to make some money off me. They changed the fluid in everything but the oil, they won't do that again.
02-09-2016, 10:57 AM
I do the full monty on my truck; I change the differential oil front and rear along with the transmission every 40,000 miles. Using Amsoil 75W-90 synthetic EP Gear oil and Royal Purple for the transmission. Both filters are changed in the transmission every time I change the fluid. Oil is cheap and it is good to get the debris and contaminates out of the transmission and differential every so often.
Remember maintenance schedules published by the manufactures is the minimum requirement need.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
02-09-2016, 11:02 AM
Agree 100%.
02-09-2016, 11:12 AM
15k in my tow rigs/motorhome
30-40 in the car.
50 with manual.
I have seen my share of 100k recommended trans fluid change interval vehicles with transmissions that give up the ghost at 105 or so. (insurance inspector)
It's not just mileage- but age also.
If you are driving 100 k a year- it will last longer than someone driving 100k in 10.
"If you are going through hell..keep going"
W. Churchill
02-09-2016, 11:14 AM
Who Dares, Wins
That would be my luck... I'd wait until 150k and the day after I hit the 5 year 100k warranty... at 100,001 miles the trans would drop out the back end!, along with some fresh water tanks!
2015 Chevy HD D-Max
02-09-2016, 12:53 PM
I'll trade trucks first. On 3 I changed trans fluid/filter at under 100K and had problems with all 3 afterward.
02-09-2016, 01:29 PM
Who Dares, Wins
I had heard that... My mechanic advised against a trans oil change on my wife's Trailblazer. He said it can either be a good thing or the car will never be right again.
2015 Chevy HD D-Max
