03-29-2017, 11:22 AM
How to Determine Tongue Wt
I have been subtracting the decoupled TV wt from the coupled TV wt . This delta is what I have believed to be the tongue wt.
But now that I have over read the tons of post wrt to a WD system I am not sure.
The last CAT scale weighing is also hurting my head
Coupled TV wt 6300 - 5660 decoupled = 640 tongue wt (steer axle-fwd scale)
TT Coupled (fwd axle) wt 2600 - 3300 decoupled = 700 tongue wt ( drive axle- mid scale)
TT Coupled (rear axle) wt 2520 - 2480 decoupled = 40 shift to fwd axle (rear scale)
(and the scale just added 20 lbs....!! )
Give me an aspirin....a scotch ... my head hurts..
Help me ...what is my tongue wt??
2017 FE 246 RKS
2011 GMC Sierra, 5.3 2wd, 4.2 gear HD towing 15k GCWR
03-29-2017, 01:55 PM
You are missing one weight: the weight of the truck alone.......
Fonzie
03-29-2017, 03:20 PM
If you are trying to determine the TW, just measure it directly. If you don't want to do that, and want to calculate by subtracting larger measurements, none of those larger measurements should be with the WDH engaged. Just measure the truck with the trailer attached but no WDH (2 truck axles only), and subtract the truck weight without the trailer.
Most of the transferred weight by a WDH from the rear axle goes to the front axle. But some of it get's transferred to the trailer axle(s). So, your numbers will be off, if you had the WDH engaged.
03-29-2017, 05:59 PM
Ok...I think
Fonzie, the truck decoupled wt is the 5660 (just the truck and hitch)
Thebrakeman, I was beginning to suspect that I needed to weigh TT and TV without the WD engaged.....
The reason I use the "big" numbers is that I tie the scale up too long using the method that windsufdog's link suggests. It take 3 weighs and totally detaching the TT. The CAT scales here in Mobile give you a 2nd reweigh for $2. The 3 weigh would cost $11, $2 and another $11
I use the 2 weighs ($11 and $2)....So I will disengage the WD before the 1st weigh....both truck axles on scale 1, the front TT axle on scale 2 and the rear TT axle on scale 3. Then decouple the trailer and get the 2nd weigh....that will give me a pure TV wt and a pure TT wt
Thanks to all....So the indicated TW is affected by WD !!
2017 FE 246 RKS
03-29-2017, 06:32 PM
Cat scales are only with in 20lbs.
Coupled needs to be with the weight distribution disabled/ unhooked or the part of the tongue weight transferred back to the trailer axles and forward to your front axle will throw off the calculations.
2016 f150 xlt scab 5.0 4x2 3.55 locking axle 36 gal fuel tank
2013 F150 xl std cab 8ft bed 4x2 3.7 3.55
2017 Micro lite 25DKS
2007 Thor Cub 165 hybrid
Husky round bar hitch
2006 Honda Shadow and 13ft canoe in the truck bed
03-29-2017, 06:57 PM
The cat scales I have used, mostly at the big truck stop chains, TA, Pilot etc, give you as many re weighs required. They expect you to leave the scale to adjust your trailer axles or pin position. Making a near 80k rig fit the legal axle weights will usually take a couple tries.
I recently weighed my TV, went home 20 minutes away, came back a couple hours later with my loaded TT and weighed with the WD disabled to calculate the tongue weight, then enabled the WD and weighed the two most likely chain link counts based on tV fender measurements to determine the amount of rear axle weight a change of one link moved to the front axle and trailer axles.
Total cost one weigh and three re-weighs.
03-29-2017, 08:45 PM
Your TW is right around 750 which is 13 percent of trailer weight, just about perfect.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
03-30-2017, 07:34 PM
98 "C" Coachmen Santara 304 FL
Scangauge, TST tpms
2 cats Tyler -Lucy
03-31-2017, 08:42 PM
If you want to check tongue or pin weight any where, check out the Sherline Trailer Tongue Scale, about a buck and a half. You'll always know if your tongue is on the heavy side.
DJsFolly
