Old 08-05-2015, 10:59 AM   #1
Exclamation how to set tire pressure when ambient is 115 degrees
We live in Arizona and are continuously hit with triple-digit temperatures for about 5 or 6 months of a year, with nights often not getting down to even 90 degrees.
How would you recommend getting an accurate reading and setting the tire pressures on our 21fbrs TT? If the outdoor air temp is high, it just adds to the pressure within the tire. The other day, our TV, which I normally maintain at about 36 psi, read about 44 all around. If I adjust it downward, then it seems to me like if the air temp dropped from 110, say, to 94 degrees or lower, wouldn't the tires be underinflated?
Do hope you guys have some good suggestions.
Thanks!
Wanderers thru Wonders
Flagstaff 21FBRS led by F150 5.4
Sun & Moon, direct us...
don1 is offline   Reply With Quote
Old 08-05-2015, 11:09 AM   #2
DocsDad's Avatar
For every 10 deg increase in ambient temp you will get about 1 psi increase. No big deal and all in the design specs. Obviously, driving also increases pressure
Set the recommended pressure in the morning even if it is 90 deg (cold pressure), before driving and before the sun beats on one or more tires as it will increase the pressure on those tires. You will have variances throughout the day and week and that is to be expected.
Expect to check pressures more often as winter approaches and temps drop (10 deg = 1 psi)
2016 Forest River Sunseeker 3100SS
DocsDad is offline   Reply With Quote
Old 08-05-2015, 11:28 AM   #3
William
WEMig's Avatar
How does the heat from the road affect tire pressure under these conditions? I've had 2 tire failures under these conditions over the last 2 summers..
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 08-05-2015, 11:34 AM   #4
DocsDad's Avatar
Here's some good info
http://www.tirerack.com/tires/tirete....jsp?techid=73
Old 08-05-2015, 12:12 PM   #5
wnelsonfl's Avatar
don't go by the charts
I also have FBRS. Just finished a 13,000 mile trip. Stock tires have 20,000 miles. I recommend 45 psi cold morning. After a few miles they will be 55 to 60 in the summer. Raise pressure to 50 cold in the winter. This worked for me.for the past 2 years
wnelsonfl is offline   Reply With Quote
Old 08-05-2015, 12:18 PM   #6
TURBS's Avatar
My tv tires are set @ 80 psi on the rear ,
Coming home from the nashville rally they hung out @ 95 psi
With tire cold set the pressure to sidewall speck and go.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-05-2015, 12:36 PM   #7
mike.t's Avatar
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 08-05-2015, 05:02 PM   #8
I put 65 in mine at 80 degrees when I left Phoenix a few weeks ago. When I got to Yellowstone I added about 3 lbs each. As long as your tires are not overloaded a few lbs low is not going to matter for a short period of time.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-05-2015, 08:27 PM   #9
I have nitrogen in my tires on my vengeance since it was new. This summer my tire shop pumped out the old and put back the new kinda a recycled thing. They tell me the tire press maintains a pressure that is more stable and does heat up the way air does. Seems to make sense my tires never are hot while I'm traveling!
rebryson is offline   Reply With Quote
Old 08-05-2015, 08:56 PM   #10
Everything I've ever read consistently states to inflate to the required (or max psi) in the AM with no regard for ambient temps, because tires are manufactured to be safe thru large temperature swings. It sort of makes sense because you could, for example, set your PSI at 6am at 30 degrees and end the day in a desert at 120 degrees without changing your PSI.
phillyg is offline   Reply With Quote
pressure, tire
