Originally Posted by dglg
I have the same issue. Took me forever to get this dialed in to correct sway. Dealer install was horrible white knuckle ride. I think I have it now but I had to use 6 washers and raise the trailer brackets. Now takes a lot of effort to get the bars on and off (even after jacking all the way up), but it does control the sway. And it makes a lot of noise. I also noticed a lot of wear on the bars on the top where it meets the trunion. Am I over-stressing this hitch?
Ram 2500HD towing a 29' TT about 8500 lbs.
I ended up dropping the two locating brackets one notch and it made a great improvement. Easy to attach, ride was much smoother and I think even economy improved
