Old 08-16-2016, 08:50 AM   #31
MarkyB's Avatar
I think I have 3 washers in the head.
The L brackets height depends your specific truck and trailer. You want them set to where the bars sit level on them at ride height. For me, that was between two holes on the brackets so I tried both and settled on the lower setting. Easier to put the bars on.
Oh check those square Bolts on them periodically, I found them loose one morning while hitching up. I guess that's why the pry bar has a wrench that fits them on it.
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
Nights Camped in 2017 : 20
MarkyB is offline   Reply With Quote
Old 08-17-2016, 08:25 AM   #32
ov845's Avatar
We love our Centerline WDH. Had for 3 seasons now(about 2K miles) works great! Adjustment and grease is the key. I'm a firm believer in metal to metal contact points should be greased. Especially where the spring bars meet the "L" brackets on the trailer. It stays quiet, no popping or creaking when slow speed turns.
Sent from my iPad using Tapatalk
ov845 is offline   Reply With Quote
Old 08-17-2016, 08:34 AM   #33
MarkyB's Avatar
Doesn't that reduce the anti-sway function?
Old 08-17-2016, 09:48 AM   #34
ov845's Avatar
Our unit looks like this
Name:	ImageUploadedByForest River Forums1471444820.111284.jpg
Any where there is movement I put grease. It doesn't effect anti-sway control what so ever. The heavy duty spring pushing against the trunnions keeps it center. The bars actually slide and shift on the "L" brackets (they're supposed to) that makes the popping/creaking noise in most cases. Applying grease to the contact points reduces wear and tear on the unit again without effecting function.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
4 X 4 Engine 5.7L Hemi Gear 3.92
Airlift 1000
2015 2809W Windjammer (Diamond Package)
Husky Centerline WDH
Old 08-17-2016, 12:29 PM   #35
rmac04401's Avatar
Attachment 117549
Happy Camping!
Airlift 1000
What do you use for Grease?
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 08-17-2016, 04:45 PM   #36
ov845's Avatar
I use a synthetic brake caliper grease. It's a high temperature very thick grease. I cut a rectangular opening in the top just enough for a 2" cheap paint brush and keep it on the trailer. Before I hook up I apply the grease.
Happy Camping!
Airlift 1000
Old 08-18-2016, 12:02 AM   #37
Coachman 312BHDS
tbln930's Avatar
I f you have the newer TS model like me the owners manual specifically says not to lube anything.
2017 Open Range Roamer RF376FBH 42' fifth wheel
2016 F-350 Lariat SCrew 6.7L Turbo Diesel SRW - Extang Fold-up Hard tonneau cover - Husky 16k Fifth Wheel Hitch
tbln930 is offline   Reply With Quote
Old 08-18-2016, 11:15 AM   #38
MarkyB's Avatar
I was thinking that but I haven't had time to to look it up.
Two different models.
Centerline and Centerline TS.
Old 08-18-2016, 11:19 AM   #39
ov845's Avatar
tbin930 is correct
Old 08-19-2016, 12:17 AM   #40
Coachman 312BHDS
tbln930's Avatar
Be careful what you read on the Internet. Some comments on towing capacity i keep reading here just aren't correct. Folks should use their own vehicle manufacturer towing specifications by model/year/option and own rv weights to calculate.
towing
