01-29-2015, 06:10 PM
#21
Husky is my floor liner and the 4 point Equalizer is my hitch. I spray paint my L brackets and bars at the contact point with a product call mower guard. Hitch works great for me!
Here some more info with pics
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
01-29-2015, 06:42 PM
#22
[/URL]
FYI - Mower Guard is just a new marketing for old-fashioned dry film aerosol graphite. So if you don't have a Napa, just about any industrial/metal supplier will sell this in "vanilla" labeling for about $6/can and you can order from McMaster-Carr, Amazon, and elsewhere.
I'm in the other camp and want metal-to-metal contact for the friction, but I coat the polished metal surfaces with Boeshield T9 to inhibit surface rusting between uses.
02-05-2015, 09:38 PM
#23
Equalizer non better
02-06-2015, 12:14 AM
#24
I have a equalizer and like it as well. But I think this could be better Trailer Sway Control Hitch Guaranteed to Eliminate Trailer Sway - ProPride 3P
Seasonal
02-06-2015, 04:27 AM
#25
Had an equalizer on my last tt, went blue ox on my new. Glad i changed, easier to hook up (not that the equilizer was hard) and a hell of a lot quieter!
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
02-06-2015, 09:13 AM
#26
Originally Posted by bikendan
Hensley and Propride are great hitches but IMHO, worth the way extra money when you have a marginal tow vehicle.
And I would argue that many people spend thousands of dollars (often $20K +) to upgrade to a truck that is overkill and isn't as well suited for daily driving when all they really needed was to upgrade from a marginal hitch...
02-06-2015, 09:24 AM
#27
Yes you are correct there is many dry graphite films on the market.
Fortunately, I work in the anti friction (graphite) industry and have samples of several. Mower guard is one of the cleanest or less messy that I know of..
I also use a mixture of slip plate and grease on the hitch head. Its far more messy then the mower guard. But its serving a different purpose.
Seasonal
02-06-2015, 09:55 AM
#28
If they are upgrading from a marginal hitch then they would be grading to the 4 point Equal-i-zer, not from it.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
02-06-2015, 10:25 AM
#29
You are speaking of moving from the "good" to the "better" option. When you go the "best" option, you've made a HUGE leap and know the difference. ProPride owners can attest to this. I've pulled with hitches in each of the 3 categories and, while I do agree that the Equalizer is a good hitch and I always recommend it for folks looking to go with a friction type hitch, it is just NOT the same animal as a ProPride or Hensley. I think you'd have a hard time finding someone that has left a ProPride and gone back to an Equalizer or any other brand. I know I specifically walked from an exceptionally good deal on a TT and went with another brand because the nose design wouldn't allow me to use the ProPride and I just didn't want to go back to the Equalizer.
02-06-2015, 12:20 PM
#30
If you have a marginal tow setup the Propride is a great option. Even if your tow setup is ideal it is a great option if you have deep enough pockets. Fortunately most people don't need it and can save a couple grand. My Equal-i-zer has been rock solid for 5 years and 16K miles and personally I wouldn't use anything else even it was given to me.
To the OP: the centerline, Blue Ox, Reese Dual cam and the Equal-i-zer 4 point have all had good reviews on the RV forums. All four work well. It is a tough choice but you can't really go wrong no matter what you choose.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
02-06-2015, 01:11 PM
#31
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
The part of your post I am taking issue with is when you state" if your tow vehicle is marginal." You don't have a perfect towing setup and then cross a line where you need a ProPride. I think any rig you can tell a difference when towing with a ProPride. As TT size and weight increases toward the tow rating of a particular TV, I think you will see a much greater increase in hitch performance with the ProPride- which I think might be kind of what you are saying. I've towed with a standard chain type hitch with friction bar, the Equalizer 4 point, and now the ProPride. There was an improvement with the Equalizer over the standard, but the difference in those to the ProPride was VERY apparent. And I towed with these on a 97 F250 PSD, a 2011 F250 PSD and now an F150 Ecoboost. Once again, I THINK we are kind of saying the same thing- if I still had the F250 PSD, I probably wouldn't opt to spend the money on the ProPride. However, I don't consider my F150 Ecoboost to be a "marginal" TV. I hear of a lot of people (even with 3/4 and 1 ton trucks) upgrading to a 5W and a lot of people upgrading their 1/2 ton to a larger truck because of sway issues they are having, even though they are under published ratings. Those upgrades typically run $10K to $20K+. I think they could have spent ~$2700 and solved their problem. Used ProPride hitches typically sell for $1500-$1800, so the majority of that investment could be recovered later, too.
Edit: Just reread your post and saw the statement of "even if your setup is ideal.." so, apparently we are somewhat saying the same thing.
02-06-2015, 01:16 PM
#32
Originally Posted by Flybob
I have a Husky and am happy with it.
X2 , good quality hitch.
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
