Old 09-29-2008, 07:40 AM   #1
jaxfl's Avatar
I bought the Colorado 4x4 Auto now what?
I bought the Colorado 4x4 Auto and need to get it set up for towing behind the MH. I am cheap so need the least expensive combination. I am also not that mechanical so need simple operation and the installation will most likely be done at Camping World. Your advice please.
Thanks.
jaxfl is offline   Reply With Quote
Old 09-29-2008, 08:24 AM   #2
Thanks.
What are you planning on towing? The tow capacity is approx 1,900-4,000 lbs depending on equipment and model.
Old 09-29-2008, 08:54 AM   #3
I think he's talking about using it as a tag-along behind his motor home.
aintgotnun is offline   Reply With Quote
Old 09-29-2008, 09:00 AM   #4
jaxfl's Avatar
"need to get it set up for towing behind the MH" "tag-along behind his motor home"
Yes behind not pulling.
Old 09-29-2008, 01:08 PM   #5
I am sorry, I misunderstood.
Old 09-29-2008, 01:34 PM   #6
jaxfl's Avatar
That's OK we all read things that are not there sometimes...
Old 09-29-2008, 05:16 PM   #7
the 4x4 colorado can be towed behind your motorhome with a tow bar or tow dolly. you will have place the transfer case in neutral before towing. transmission left in park and transfer case in neutral. a two wheel drive colorado cannot be towed with the wheels on the ground. you would need a car trailer and have all 4 wheels off the ground. the owner manual will out line this under Recreational Vehicle Towing.
skidoonut is offline   Reply With Quote
Old 09-29-2008, 07:35 PM   #8
Ya, I was thinking of the Chevy Colorado pick-up truck.
