Old 02-07-2013, 03:04 PM   #11
You need to have a TW of between 10-15%, so pick 12.5%. If the TT is 3800lbs dry brochure weight, then figure a couple 100lbs over for delivery. Then figure 1000lbs or so for stuff, that puts you at 5000lbs loaded. Obviously you'll need to figure your own weights but as a base figure 5000lbs ready to tow. 12.5% of 5000lbs is 625lbs. You may have 500lbs (10%) or as high as 750lbs (15%) of tongue wieght. I would get 800lb bars based on what I know from past TT's I've had.
goduc is offline   Reply With Quote
Old 02-07-2013, 04:27 PM   #12
Thank u all very much I was able to cancel my order of the 600lb and reordered the 800lb with no problems this should work I do think the1000lb would be too much thanks again everyone for the quick responses in time to change my order
adanielsiii is offline   Reply With Quote
Old 02-07-2013, 04:36 PM   #13
After doing the math dry weight is 4,050 delivered 100 l a for delivery 1000 lb loading 5150 lbs to 5200 give or take ready for camping that leaves between 600 and 700 lbs tongue weight thanks again
Old 02-07-2013, 04:50 PM   #14
MtnGuy's Avatar
800 lb. bars should serve you well. When I was on the Trailmanor forum, the typical tongue weight on those trailers were around 500 lbs. Several members got WDHs with 600 lb. spring bars, and said they did not distribute the weight sufficiently. I learned by their mistakes, ordered 800 lb. spring bars for my Trailmanor, and they worked great.
Old 02-07-2013, 04:52 PM   #15
I thank u again before it was too late to cancel me order I am excited to get on the rd just gotta weight for the warm weather and the snow to melt
Old 02-07-2013, 05:09 PM   #16
BillyBass's Avatar
wd
Originally Posted by adanielsiii View Post
I have a 2009 cherokee grey wolf 24rb not sure what size wd to use
What does wd stand for
BillyBass is offline   Reply With Quote
Old 02-07-2013, 05:12 PM   #17
TURBS's Avatar
Weight distribution
Turbs
Old 02-07-2013, 05:12 PM   #18
Weight distribution
Old 02-07-2013, 05:13 PM   #19
BillyBass's Avatar
thats what i thought are you having a sway problem
Old 02-07-2013, 05:14 PM   #20
No I'm new to camping and just bought a rv and wasn't sure what weight distribution to use or how to figure it out
