Old 12-29-2013, 06:35 PM   #1
NELA
Weezer's Avatar
If you had a choice of a 5er hitch...
would you go with a Husky or a Reese?
And, if you go with the Reese (which is where we're leaning) which model would you prefer, taking in to consideration that the 5er will have the new Reese Revolution pin? (i.e. a non slider hitch)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 12-29-2013, 07:19 PM   #2
Fulltime family RVer
Sigh, lost a reply to the ether.
I'll second what was mentioned in the other thread- the B&W brand hitch. It's a gooseneck hitch that has it's own Companion fifth wheel hitch. It's more expensive because of this, but the hitch is extremely well built and honestly, I can't figure out how you could high hitch or mishitch it in anyway. I won't use the term "foolproof", but it's as close as I can imagine.
It's fans are rabid cult-like fan boys.
http://www.turnoverball.com/products...th-wheel-hitch
What originally drew me to it was when you take it out of the truck, you're left with a perfectly flat bed. And it comes out in 2 manageable pieces instead of 1 heavy one.
Old 12-29-2013, 07:36 PM   #3
dcheatwood's Avatar
My Reese separates also, with one large pin holding the two pieces together. Two Heavy pieces. Lol.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 12-29-2013, 07:40 PM   #4
Ha! I wasn't sure how many did that. The B&W Companion base isn't so much heavy as it is awkwardly sized. I generally lower it directly down to a furniture dolly and roll it around. The coupler top isn't very heavy.
Old 12-29-2013, 08:20 PM   #5
dcheatwood's Avatar
I leave mine hanging on the pin and drive out from under it.
Old 12-29-2013, 08:38 PM   #6
jonrjen's Avatar
I purchased a Curt 16K and have used it one time to take the Wildcat in for service. I just ordered the Curt Q24 off of Amazon for $514 delivered.
Amazon.com: Curt 16245 Q24 Fifth Wheel Hitch: Automotive
When I had my F550 Ranch style bed I used the BW Companion hitch simply because the truck came with the BW gooseneck installed. However I am one of those strange weird off the wall people who like having the hitch rails mounted in the bed of my truck. They offer extra tie down points should I ever need them for strapping down a load. Of course they also offer a trip over my big feet option also.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 12-29-2013, 11:31 PM   #7
I have this one, works well, impossible to hi hitch, well almost, mine's older without the locking jaw.
16k Double Pivot Slider | Demco Products
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 12-30-2013, 12:19 AM   #8
I have a crew cab with the short bed so I installed the aftermarket Reese sidewinder pin like your Revolution. Also went with the 16 K Reese with the double jaws and bed rails. I take the hitch out after each use and the head comes off with one large pin so I can remove it with only limited strain on my "older" body .
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
Old 12-30-2013, 07:56 AM   #9
Jjsav's Avatar
I have the Reese R16K Slider and I like it. Had an issue with the isolator bushings which reese fixed. I also have the Reese Revolution on my unit and have not needed to use the slider yet. I agree that it is nice that it comes a part for easy removal. The slider part is awkward to take out.
2018 Jayco Eagle 355MBQS
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
Jjsav is offline   Reply With Quote
Old 12-30-2013, 08:07 AM   #10
jevanb's Avatar
with a short bed truck, my pick would be Pullrite Superglide... no levers to throw just go..
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
5er, hitch
