Old 06-02-2016, 05:21 PM   #31
You asked about a 5er .............
sgt, you asked about a 5er. There are a lot of pros and cons but having the hitch over the axle adds hugely to handling, especially if you are talking over 20-24'. Height and therefore wind-load is maybe the biggest downside, especially if your are 6' plus and want to stand upright in the bedroom. I.e., you will lose mpg with most 5ers. Mostly I wanted to mention that there are quite a few "ulta-light" 5ers available now. Mine is 32' (outside) and 7700 lbs dry and max 9000 lbs loaded. My particular one is "designed to be towed by a 150/1500 truck" but after looking for a 150/1500 to do so I found only maxed-out ones would do it and without much margin. Instead I went with a non-maxed-out 250/2500 and always have 500# or more of margin in the payload department. And I'm 4000# below my tow rating (this is a gas 250/2500). My Ultra-light has just 1200# on the hitch dry and maybe #1300 loaded (I pushed mine up closer to #1400 by moving stuff forward, spare tire from the back bumper to under the bed, etc because only 15% of the weight on the hitch is less than generally recommended for a 5er). Most ultralights are #1300 or #1400.
If you go this route, check hitch height vs 5er hitch adjustment range. Mine sat way to high at the front due to the higher bed of the 250/2500 truck so I had to add 3" spacers where the axles mount to get the trailer more-or-less level.
Didn't mean to high jack the thread; the OP asked about a 5er in his future. My bottom line is maybe but you will still want a 250/2500 truck unless the 5er is 20-24 feet or less and not a heavy one.
The OP also asked about a generator. The very expensive Honda 2000 is worth its price (twice that of similar cheaper ones) but is only 1600 VA (less than 1600W if the load includes motors) continuous and won't run some A/C units. Quiet, easy starting, easy to maintain, and at 46# about as light is you are going to find at that power rating. You can buy a "companion" that interconnects and doubles the power handling. Also has a battery charger built-in (unregulated).
Hclarkx is offline   Reply With Quote
Old 06-02-2016, 05:35 PM   #32
Blackrock's Avatar
Originally Posted by walk_the_walk View Post
My next door neighbor's sister and his brother-in-law both perished trying to use a smaller truck to pull a larger travel trailer, one that exceeded the ratings of the truck. If I recall the story correctly, they were going down a large hill on a paved road and the trailer started swaying back and forth and this caused them to lose control and crash. Both of them died. This is a 100% true story.
If you were to ask him about it, he would definitely urge you to go with a bigger truck, and have a margin of safety.
I have two friends, one had a Nissan Xterra and the other a smaller Toyota truck who had fairly large trailers who walked away with their lives when their trailers whipped and flipped.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 06-02-2016, 06:39 PM   #33
You are close and that is OK.
Truck
7200 lbs total...
3750 lbs front axle... 3320/3060 lbs
3850 lbs rear axle... 3640/4000 lbs... the 4000 is over
Trailer
10500 lbs max wt... 6140 lbs
1050 lbs hitch weight
Tires are rated at 2535lbs each so you have some safety margin built into them.
Now the question is what are the weights with the four passengers + gear and where is that weight distributed? I suspect the truck will be overloaded but not by much. What can you put in the trailer over the axels to bring the truck weight down? You have lots of margin on the trailer but don't put more weight in the basement, try for near the axles.
p.s. Why are you hooked up to tow with the TV antenna up? That should be part of your pre-tow checklist. Before we move an inch we have two to four walk arounds and interior checks. My wife and I always see things that the other missed. It just make you safer, the trip easier, and cheaper.
nrkmann is offline   Reply With Quote
Old 06-02-2016, 07:35 PM   #34
I can't agree more on the walk-arounds. Wife is more likely to catch something missed (by me) so she does the last extra walk around. But, she won't kick the tires ... I have to do that ... and do so at every stop as well.
Old 06-02-2016, 07:43 PM   #35
..............Now the question is what are the weights with the four passengers + gear and where is that weight distributed? I suspect the truck will be overloaded but not by much. What can you put in the trailer over the axels to bring the truck weight down? You have lots of margin on the trailer but don't put more weight in the basement, try for near the axles..............
I can't argue with your assessment, but I have to wonder how manufacturer's set their truck's limits. By testing to failure? By driving in windy conditions? We've all seen trailers moving around more than we would want to experience. I don't think the prudent RV'er can have too much margin. My inclination is to suggest 25% ... i.e., stay below 75% of any and all ratings.
Old 06-02-2016, 07:56 PM   #36
The manufacturers ratings are such that they will not be sued. I would guess that the test to failure rate is 200% to 300% of published capacity. I have done many short hauls at 150-175% of rated hauling capacity. But I have overload springs and shocks with 3X stock piston size to hold the load and stability.
My TT loaded and truck loaded is right at the max published ratings and I have not problems. With 50K on the clock, 15K towing, it just hums along. TT tires are only rated to 50mph so I am not going fast either.
Old 06-02-2016, 09:06 PM   #37
I have a 2013 F150,V6 eco boost and the same integrated trailer brake and the same rear end-3:55. This rear end will tow 9300 lbs as equipped and your trailer is 7200 dry? My 5th wheel is 6800 dry and I don't have any problem pulling it. I have added air bags to the truck and works great. Water weighs 8 lbs per gallon, so ease up on filling it up. Clothes and other stuff shouldn't put you anywhere near overweight.
mas10r is offline   Reply With Quote
Old 06-02-2016, 09:30 PM   #38
Crookedread
crookedread's Avatar
Accuracy counts
All of this assumes that the numbers were accurate. I found that the weight of the trailer was heavier than stated. Accessories were not added and even accounting for them the trailer was heavier. Items people take usually add up to more than they think. I suggest that you load everything including water and gas and proceed to the nearest scale. Weigh front axle, rear axle, trailer axles and then weight one side of the trailer axles. This will give you accurate loads. The last weight is to make sure you are not over loading one side of the trailer. And I suggest a very good hitch with bars and an anti sway device. Drives awesome at maximum weights. Tundra pulling 2312 Stealth with 2 four wheel drive quads inside. If I take two people in the truck, Truck is overweight so I am very close to max.
crookedread is offline   Reply With Quote
Old 06-02-2016, 10:59 PM   #39
kc5mhb's Avatar
My thoughts exactly. You never want to be at 100%. As a rule of thumb, I use 70% as my maximum, that way you have wiggle room and you are not pushing your truck to the limit or beyond. My trailer weighs 6230 dry with a max of 7868 pounds. At best I might add 300 pounds with food, clothing and propane to the 6230 which brings me to about 6500. My tow rating is 10,000 pounds with a GCWR of 20,000. Even with my golf cart in the bed of my truck, I'll never get close to the GCWR fully loaded with 6 occupants and a full tank of gas.
2015 Cherokee Limited 274DBH
2000 F250 CC SD V10 4X4 8' bed, 4:30 gears, SCT X3
2007 Mustang Convertible V6 - Lots of GT mods
1965 Mustang Coupe I6, 3 spd. manual
1963 Thunderbird Landau 390
kc5mhb is offline   Reply With Quote
Old 06-03-2016, 01:49 AM   #40
Casino Camper
jughrad's Avatar
Originally Posted by thebrakeman View Post
Not enough info in the OP, and I'm feeling too lazy to see it came in a later post. But if the F150 is going to be used, the WDH is not set up correctly.
Front "Steer" weight:
Truck only = 3500
With trailer, no WDH = 3060
With trailer, with WDH = 3320
That 3320 should be as close to 3500 as possible (back to stock front loading). You need to transfer a LOT more weight, which will also help remove some weight from the rear axle, helping with some cushion to the rear GAWR.
I agree. Shift another 250lbs back to the trailer. If it is an EAZ Lift it could be as easy as one more chain link. You might need to tilt the ball forward/down to keep the bars even. I think it would be a reasonable tow for periodic travel.
Since my vehicle is a daily driver and I only use it as a TV getting to and from CG, I prefer a 1/2 ton with gas 6.2L. It is a softer ride for daily commute and maintenance is much less than diesel. TT averages 6700 with 10 gallons fresh water, wood and gear and I don't sag more than a half inch. With the 6.2L I don't break 3500 RPM at 8% and tranny stays below 180F. My point here is that a half ton with big engine or high gear ratio is capable for periodic tows for a 7000lb/30ft trailer but it won't last long if you intend to tow cross country.
jughrad is offline   Reply With Quote
weight
