Old 12-31-2018, 03:03 PM   #1
Improving F150 handling
Purchased a new F150 with ecoboost turbo and HD tow package. Sales person said it could tow 13,500 lbs. New Tt is 30' Wildcat. Sway and handling is very bad. WDH AND SWAY control seems to be adjusted correct? Is this F150 enough truck for this trailer. Power is great but handling is very bad. Anything can be done or installed for this issue.?
davechamp is offline   Reply With Quote
Old 12-31-2018, 03:10 PM   #2
Canadiancrew's Avatar
The first step is get LT rated tires or at least pump the p rated ties up to 44 lbs when towing. If your truck came with the OEM Goodyear jello balls you can push and pull on one of the back corners of the truck box and watch the sidewalls roll. Make sure your wdh lets the back of the truck squat a little. Your suppose to eqaulize the weight but if the back of the truck is a little light it becomes a white knuckle drive.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 12-31-2018, 03:12 PM   #3
Denver To Yuma In 90 Days
How much does your trailer weigh (not dry weight)?
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote
Old 12-31-2018, 03:16 PM   #4
I have a 2017 F-150 with tow package for my lighter and shorter 2507S (6800 lbs when loaded). What I found on my first trip was getting the weight distributed properly helped it handle better. Bought a tongue scale that let me get more of my weight (10-15% total of trailer weight) on the front tongue which really help eliminate the little sway I was getting.
If you haven't already, go to a CAT scale with the trailer attached for a weigh and see how much your trailer is weighing loaded. Second, check your front and rear truck height before and after attaching the trailer with the WDH to ensure you are good there as well. Hope this gets your sway issue resolved.
Delnari is offline   Reply With Quote
Old 12-31-2018, 03:17 PM   #5
Estimated loaded weight about 9000 lbs, dealer changed stock tires to LT rated because stock tires were not rated anywhere near what the truck was rated to tow. Am thinking about suspension addition or modifications?
Old 12-31-2018, 03:18 PM   #6
bikendan's Avatar
First, don't think the F150 has a HD tow package.
It has the standard tow package or the Max Tow package.
You can get the HD Payload package though, on some models.
Second, what is the truck's payload capacity?
Third, what WDH system do you have and do you have pics of the combo?
Fourth, are the tires P series or LT series and what psi are you running them at?
Lastly, NEVER believe what comes out of a salesperson's mouth. Always verify on your own.
You'll always run out payload capacity before ever coming near the 13,500lbs max and that number is ONLY for specifically spec'd F150s.
By the way, folks, the OP appears to have a Toyhauler, even though it's not listed in their profile. How they have it loaded may be the cause of their issues. Could be light on tongue weight.
Equalizer WDH
Old 12-31-2018, 03:28 PM   #7
any salesperson that says a 1/2 ton truck can tow 13k is a true sales person and a few terms I cant say here
Kimber45 is offline   Reply With Quote
Old 12-31-2018, 03:40 PM   #8
My Xlr 29 hfs is being towed by my Silverado 2500Hd, perfect!! New TT and F150 is new.
Old 12-31-2018, 03:48 PM   #9
acadianbob's Avatar
A rear anti-roll bar is a great addition and is inexpensive. Hellwig makes a good one.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 12-31-2018, 03:57 PM   #10
let me get this right you have a 29hsf and a chevy 2500hd . why buy a ford you just took a huge step down . can you not tow your new tt with the chevy ?
MR.M is online now   Reply With Quote
f150
