Old 09-13-2013, 02:50 PM   #1
EricInColorado's Avatar
Infinity QX56 (or Nissan Armada) owners?
Say, does anyone out there tow with an 4WD Infinity QX56 from the 2004-2010 model years? Just wondering how well it might pull a 3500lb (dry) Roo 183. Thanks!!
Eric, Tara, and most of China
2013 Camping Nights: 2
2014 Camping nights: 31
TT 2014 Rockwood Roo 183
TV 2012 Nissan Armada
EricInColorado is offline   Reply With Quote
Old 09-13-2013, 02:58 PM   #2
I should add:....or a Nissan Armada, because they're 99% the same.
Old 09-13-2013, 04:48 PM   #3
KDHfan's Avatar
I tow with a 2012 Armada SV. Tow rating of 6500# (yes, I'm sure it's 6500# and not 9000#, but that's another story). I have a Rockwood 2306 with a yellow sticker weight of 3900lbs. We don't haul much... So I'm sure I'm under the gross rating of 4800lbs. I use the 4-pt Equalizer WDH with integrated sway control. I've had zero issues towing with the Armada... It's a great tow vehicle as long as you keep the length to a minimum. I run in tow mode... RPM's run about 1600 on flat and 2200 up hill.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 09-13-2013, 11:27 PM   #4
wyo700's Avatar
I had a 05 Nissan Titan that I pulled my 26 foot toy hauler with. Weighed 6800 loaded. The truck did very well. I now have a Toyota tundra 5.7 and I am happier with this truck. But with the weigh you want to pull you will be fine. And the QX56 has a little bit different engine design and has higher horsepower and torque ratings that my Titan and armada have. I think you will be very happy.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 09-14-2013, 01:46 PM   #5
bikendan's Avatar
Eric, i'm sure there's someone in the Roo/Shamrock sub-forums that's towing with the Armada. you might look there also.
but if it has the factory tow package, i think it'll easily tow the 183, even in the Rockies.
is the Pathfinder not doing the job well enough?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-14-2013, 08:44 PM   #6
I'm not sure if the Pathfinder will tow it well, I don't have the Roo 183 quite yet! Next Friday it arrives. I'll probably tow it up to 10kft to see how it handles.
Mostly, my OCD is car shopping. I can't stop. In my defense, I buy used and only drive about 10k miles per year.
Thanks for the info on the Armada SV and the Titan!
Old 09-15-2013, 12:54 AM   #7
bikendan's Avatar
realize that the Titan is infamous for the worst gas mileage of any of the 1/2 ton trucks and i've heard that the Armada is nearly as bad, since it's based on the Titan platform.
Old 09-15-2013, 01:33 AM   #8
asquared's Avatar
I used to tow the tt in my Sig with an 04 armada le. It was 4wd. It handled a 5000 lb 2 horse trailer no problem. It towed a car and a larger boat no problem but it struggled with my 7000 lb tt, especially on the hills. By struggling I mean feeling everything that passed me including cars and SUVs. I had a lot of tail wagging the dog. I barely made it up a 7% grade and really got pushed coming down a 7% grade despite having a prodigy p3 brake controller.
If you get one with the tow package you should be fine with a tt that weighs 3500 lbs. Just double check your loaded weights and tongue weights as the weak point on the armada is the payload. With a family of 3 and a 70 lb dog my armada only had 800 lbs payload left for tongue weight. So you should be ok up to about 5000 lbs loaded weight. I would not go any heavier than 5000 lbs loaded though.
Ps if you get a year that has load leveling suspension turn the armada off and adjust the wdh with load leveling suspension disengaged. It took a lot of work and trips to the scales to figure that out.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-15-2013, 01:35 AM   #9
asquared's Avatar
With our old armada we got about 13mpg without tt and 6-8 mpg towing on average.
2014 Sabre 34REQS-6
Old 09-15-2013, 10:12 AM   #10
Wow, anaro, that's terrible mileage! My neighbor had an Armada and did complain about the mileage. Maybe I'll continue obsessing over a Sequoia.......
I sure wish I could buy a truck, there's SO many more engine options. But I need the passenger space of a 3-row SUV.
