12-18-2015, 11:57 AM
#41
CURT Manufacturing 19101 RV Bumper Receiver Hitch Rear - 3500lbs. Gross Trailer Weight - 350lbs. Tongue Weight - 2 in. Square Bumper - Incl. Hardware - Caution Never Exceed Your Bumpers Gross Towing Weight
Specs state not to exceed Bumpers gross warning.Do you have a rating or maybe 100 pounds for spare tire perhaps?
B and B
12-18-2015, 11:58 AM
#42
He exceeded the bumper load rating by installing the hitch......
12-18-2015, 12:02 PM
#43
Is double towing in NJ even legal? I know up here it is not unless you have a fifth wheel.
B and B
12-18-2015, 12:04 PM
#44
Left Coast
Ultra-Lite unit?
12-18-2015, 12:05 PM
#45
No it is not legal in NJ.
12-18-2015, 12:06 PM
#46
It's a v-lite
12-18-2015, 12:08 PM
#47
Left Coast
Mississippi is where I think OP lives
12-18-2015, 12:09 PM
#48
Legal there.
But I bet not a bumper to a bumper pull.
12-18-2015, 12:21 PM
#49
Originally Posted by Boss
pictures
speechless... and that's saying alot for me
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
12-18-2015, 12:24 PM
#50
Left Coast
Unless it's the train you posted awhile back!
12-18-2015, 12:25 PM
#51
For the OP.
We are trying to make sure you don't end up with either damaged trailer, other vehicles or worse yet loss of life. I did read your profile and I stand corrected on the state you live.
It says you can triple tow. But that hitch on the bumper is scary.
B and B
12-18-2015, 12:32 PM
#52
B n b the bumper scares me more then the hitch!
12-18-2015, 12:35 PM
#53
And the warranty if there was any is void.
12-18-2015, 12:55 PM
#54
Left Coast
Mr. Miller would become a best friend.....And his roll of wire...
12-18-2015, 01:06 PM
#55
.035 should be sufficient
12-18-2015, 01:10 PM
#56
Left Coast
Turbs...here's a thought...if you built steel poles, then, in a bind, a guy would have some strut material on hand
12-18-2015, 01:11 PM
#57
True!
12-18-2015, 01:14 PM
#58
Left Coast
Forgot, they'd need to be square tubing as it's easier in some cases to work with
12-18-2015, 01:24 PM
#59
Install reinforce
Originally Posted by CAT-RN
Guess you have to hook something to back to figure where or if you need to reinforce frame. Lol
Russell
The Rpod has a good sturdy Channel frame. Not like the "sheetmetal" frame on larger trailers. I used pieces 2"x3" tube steel to weld crossways between outside channel to weld "drawbar" back to receiver. And added reinforcement steel to very back of stock channel frame which was welded also to the receiver tube. I would send u a picture but right now the trailer has a full cover on it and bunch of snow on top of that.
I only tow a trailer for my RZR loaded slightly forward of the center balance weight of the trailer loaded with a tonque wt of about 80 lbs. I probably would not got with much heavier tonque wt, just to be safe.
12-18-2015, 01:40 PM
#60
pictures
First I will say I would not use that hitch towing but here a couple of ideas than may or may not save form losing the trailer.
I emailed these guys and ask them if put one each side (using 4 of them) of the frame would that work and they said yes. I just have 100 lbs worth bikes in the hitch and I remove the spare tire and grill that weight 135 lbs.
https://www.mount-n-lock.com/mnl-car...bumper-failure
This also may work but again may not - depends on your frame.
Products
I haven't decided it I'm going to install the brackets or do right and order a receiver from Lippert the company that made my frame that I know is approved to work.
RV Bike Racks & Receivers for Sale
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
