04-20-2018, 03:01 PM
#21
I have an F250 V10 gas and thought about an auxiliary tank, but i have not found any for gasoline, just diesel. Can you get a auxiliary tank for gasoline or is it too flammable?
2015 Phoenix 32RE
2002 F250 V10
04-20-2018, 03:08 PM
#22
Looks like Titan has a couple of options. http://titanfueltanks.com/faqs
04-20-2018, 03:24 PM
#23
I had mine set up with the solenoid but found it got too hot for my liking, actually burned my arm. So I switch it to a motorized ball valve and a three possession switch, open, off, closed, no heat buildup.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
04-20-2018, 03:41 PM
#24
Why do people assume that if you have an auxiliary fuel tank that your going to drive hours on end without stopping. I have a 60 gal. auxiliary fuel tank, plus the 36 gal. tank that came with the truck. Towing our 5th wheel, I could go almost a 1000 miles without stopping, Do I, hell no, that would be insane. We try to travel no more than 400 miles per day with rest stops in those 400 miles. We refuel mostly without the trailer in tow, do not have to worry whether we can get into the station or not.
04-20-2018, 03:50 PM
#25
I think its more of a choice of when you fill up rather than having to fill up, I do about 300 miles a day and have stops in-between, if I want to go longer I can.
04-20-2018, 06:25 PM
#26
My body says 400 or less but tomorrow it will be 540. A long day but we plan on starting early. I normally drive 63. I can do right many miles but I have to see a rest stop about every 200 miles or else my bladder will explode
04-20-2018, 07:30 PM
#27
My 2017 3500 Sierra came with a 36Gal tank...unfortunately, the2500 that I traded in had a 52Gal replacement tank.....DW said 36 was unacceptable, so I added a 40 Gal Titan auxiliary tank.....now we have some serious range. Now re-fueling after a day's travel isn't necessarily a high priority.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
04-20-2018, 07:55 PM
#28
Jack of All Trades
Is the solenoid petroleum rated/explosion proof? If me, I would worry if it weren’t.
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
04-20-2018, 07:59 PM
#29
Rick
I put this one on after experiencing the heat generated by the solenoid one
Motorized Ball Valve- 1/2" Brass Ball Valve with Full Port, 9-24V DC and 2 Wire Reverse Polarity by U.S. Solid
04-20-2018, 08:01 PM
#30
Originally Posted by banda
Captain America, how much did your tank cost?
$142 on Ebay
I'm in this around $200 for cell, solenoid, switch, fittings
2018 Refection 311BHS
2011 Wildcat 32QBT (SOLD)
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor, EFI Live
Jack of all trades, Master on none
04-20-2018, 08:03 PM
#31
Rick
Yes, solenoid is for fuel
04-21-2018, 06:43 AM
#32
Thank you for sharing the information and pictures. Much appreciated.
04-21-2018, 08:59 AM
#33
Nice setup, curious how you fill cell up with the tool box above it?
04-21-2018, 09:04 AM
#34
Originally Posted by dblr
Very nice job, we can carry 240 gallons of fuel so I can REALLY plan to fill up when ( IF ) we find diesel cheap.
That's an additional 2040 lbs of fuel. WOW !!
04-21-2018, 09:10 AM
#35
True but truck rated for 80,000lbs
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
04-21-2018, 09:12 AM
#36
Not a problem for him, he tows with a Kenworth.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
04-21-2018, 09:58 AM
#37
Hey Captain do you mind explaining how you added bulk head fitting? Was it something that had to be welded in ? Also could you mount it lower to get all of the fuel out of the aux tank ? Id like to mirror what you have done as the EFIlive isnt getting me enough mileage to keep up distance wise with my long bedded buddies . Especially when we make the haul from the left coast to Montana to hunt .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
04-21-2018, 03:30 PM
#38
The filler for the fuel cell protrudes through the bottom of the toolbox. My original plan was to extend the filler neck up 10" for easy accessibility, but since I'm rather tall (6'1"), I can reach in without a problem.
The tank is design for top feed with a pick up, return, and vent. I capped the pick up and return then added a filter for the vent.
The bulkhead fitting I used is designed for fuel and has two washers and a nut. Simply drill a hole as close to bottom as possible, install fitting, put washer and nut on inside and screw till tight. To access the inside of fuel cell, I had to remove filler neck, it is held on by 12 bolts.
The pick up tube is about 1/2" from bottom of tank and my bulkhead fitting is slightly higher. I think I could of made it lower to drain more fuel, which I did not do. Measure twice, cut once. Too late now!
04-21-2018, 03:55 PM
#39
240 gals. of diesel?
WOWZA! @ $3.00+ this summer unless you plan to push it. Don't forget,
Saudi Arabia's budget is shot and they are going to take it out of our hides, and...tanks! Arghhhh...
Si Hoc Legere Scis, Nimium Eruditionis Habes!
04-21-2018, 05:18 PM
#40
I left Pigeon Forge TN this morning on a trip to Topeka IN to have some work done on Cedar Creek, diesel was $2.62 a gallon, saw diesel on the way up here for $3.33 a gallon. Diesel here in Topeka $3.09 a gallon. I have enough diesel in my auxiliary tank plus trucks tank to pull camper up here and back to Pigeon Forge and not have to buy any diesel
