Old 07-08-2015, 03:09 PM   #1
340_Formula_S's Avatar
Installing 5th wheel Monday
Does anybody have feedback to offer on the B&W tournoverball Companion system?
340_Formula_S is offline   Reply With Quote
Old 07-08-2015, 03:16 PM   #2
Myaamia
Leathernek's Avatar
This is what I have and it is way easy in and out. I have only limited experience, just started RVing with my F350 and REBH371 this spring,. We been out 4 times and no problem with this hitch.
Companion OEM - 5th Wheel Hitch - Fits Ford Puck System | B & W Trailer Hitches
Scott & Tammie
2015 F350 4x4
SRW 11,500 GRVW Pkg
2015 Sierra 371REBH
B&W Companion 20K
Leathernek is offline   Reply With Quote
Old 07-08-2015, 04:00 PM   #3
Crockett's Avatar
they did have an issue with a few years ago when they first came out. the cross rails on the ford bed would not support the hitch well on heavier trailers. if you got a ford, you might want to check. b and w will give you the heads up.
Crockett is offline   Reply With Quote
Old 07-08-2015, 04:17 PM   #4
Ram 3500
Old 07-08-2015, 04:54 PM   #5
Crockett's Avatar
no worries then...well constructed...good jaw mechanism..very little slop if any
Old 07-08-2015, 05:56 PM   #6
We have the B&W hitch. It's very easy to use and the bed of your truck is totally flat when not using the hitch. Highly recommend it. We have it installed in a Silverado 3500 diesel.
Sent from my SPH-L720 using Tapatalk
jllburns is offline   Reply With Quote
Old 07-08-2015, 06:13 PM   #7
CWSWine's Avatar
We have about 1200 miles on last month and seems to work fine. I would purchase one again..
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
5th wheel, wheel
