Old 12-20-2014, 07:56 PM   #1
elika63's Avatar
Installing new brake controller
I'm about to purchase a new Prodigy P3 controller for my 2013 GMC Sierra and need to know if I need to purchase a GM harness or just hook up directly. I'm pretty sure I'm pre-wired, however, have no clue which wires to use. I see a harness already mounted below my dash (but believe this is used to read engine codes?) and also another set of cut wires tucked above (that I've pulled down in photo). I'd like to get the harness but not sure if I even need it. Click image for larger version
Name:	ImageUploadedByForest River Forums1419126958.660922.jpg
elika63 is offline   Reply With Quote
Old 12-20-2014, 07:59 PM   #2
Flybob's Avatar
Did you get a brake Controller harness with the vehicle when you purchased it. Mine was in a bag in the glove box.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-20-2014, 08:00 PM   #3
elika63's Avatar
Flybob , no I purchased the vehicle used.
Old 12-20-2014, 08:02 PM   #4
elika63's Avatar
Also, do I need to do anything under the hood in the fuse box? I've heard that I may have to find the wiring and fuse for that as well.
Old 12-20-2014, 08:26 PM   #5
raspivey's Avatar
Old 12-20-2014, 09:10 PM   #6
I can't tell you 100% but I'm guessing you're ready to just wire it in. I added P3 to a 2011 Chevy Express Van that had the same wires you have under the dash. (If a basic vehicle like a cargo van is pre-wired and ready to go, I'm guessing your pickup must be.) No fuse box work needed. It was as simple as connect the four wires from the controller to the four under the dash and done. One word of advice is to pay attention to wire color as the P3 wire colors don't match the trucks (red doesn't equal red and so on) and mis-wiring can cause damage to the controller. Good luck with your project....
taken is offline   Reply With Quote
Old 12-20-2014, 10:10 PM   #7
Since you don't have the plug under the dash, just the wire pigtails, you'll have to splice them to the end of the harness that comes with the P3 as shown in the video raspivey posted.
Here's the controller at etrailer:
Tekonsha Prodigy P3 Trailer Brake Controller - 1 to 4 Axles - Proportional Tekonsha Brake Controller 90195
Fast delivery. I've got the same thing in my 2009 Silverado, only I had the connector under the dash. GM's gone cheap in the last couple of years.
You'll probably have to do the wiring thing at the fuse box, as shown in the video. (I had to buy the 2 nuts, different sizes, of course, and two fuses, one for brakes and one for the aux power.)
2011 Traverse LT, 3.6L, FWD
Old 12-20-2014, 11:20 PM   #8
bikendan's Avatar
Rockfordroo has it right.
GM made the change in 2007 to bare end wire bundle for the BC.
I just spliced the Prodigy OEM harness to the bundle.
no more plug in harness, like in previous years.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 12-21-2014, 08:42 AM   #9
elika63's Avatar
Thanks guys! It didn't make sense to purchase the extra harness if I could hook up the controller directly to the wires. Good to know GM is cutting corners. I'll check under the hood for the fuses.
Old 12-21-2014, 08:51 AM   #10
Flybob's Avatar
Also check the fuse for the 12V Acc power, Tow packages usually have the wire installed, but leave the fuse position open.
TST Tire Monitors
2 100W solar panels
brake control, controller, brakes
