Old 04-07-2016, 09:26 PM   #121
Too Tall's Avatar
This thread has gone south in a hurry, I suspect this thread has run it's course anyway.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-07-2016, 09:36 PM   #122
Oklahoma Proud
MillerTime's Avatar
Lol!
I said that people's panties would get in a wad if i was honest about trucks!
Old 04-07-2016, 10:19 PM   #123
A turbo diesel is just getting broken in at 100K and will go close to million miles if well maintained. Truck mfg have had a long time to perfect their models. Especially their drive trains. Most of the larger truck automatic transmissions will do 500K, like the Allison and Aisin transmissions. So, for the casual driver who goes on vacation or does not pull anything most of the year, the newer trucks will last a lot longer than your pedestrian family car.
There is not a bunch of changes over the years like passenger cars. No arms race to have the latest technology packed into them. Its the electronics that give new vehicles nightmares.
And yes, you can buy a 2012 Ram 4500 like mine for under US$20K with less than 250K miles. You can get a 3500 or 2500 with basically the same motor for even less. I have probably driven more miles in the last 25 years than most of those who have posted in this thread put together.
I did buy new but that is because I wanted to. And yes, I have 250K miles in three years. My job takes me all over the country and I enjoy being comfortable. I cut my teeth on Chevys but over the years, I have gravitated toward the Rams for their overall reliability.
I do not have to impress anyone. I do not have to explain myself. Take my years of experience and the millions of miles I have driven in diesel for what its worth.
But to call a 2012 Ram old, cheap and unreliable is just ignorant.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 04-07-2016, 11:09 PM   #124
Oklahoma Proud
MillerTime's Avatar
I guess this from 2012 is ignorance and the last one is for 2015.
Matches up pretty good with what we see in the shop.
I guess most people dont know that all those otr trucks might have 1million + miles, but usually have in frames done somewhere between 450k and 750k, with complete rebuild a little after or before that 1 million mark. They also have had several clutches, trannys gone thru and most every other part replaced or worked on along the way.
So maybe 100k is not much for the block on a light duty, but everything else is probably already 30-70% thru its life span.
(Im sorry, i held back as long as i could.)
ID:	104228   Click image for larger version
ID:	104229   Click image for larger version
Old 04-08-2016, 12:55 AM   #125
[QUOTE=MillerTime;1156717]I guess this from 2012 is ignorance and the last one is for 2015.
(Im sorry, i held back as long as i I've gotta say that if a semi has had several clutches in a million miles I feel very sorry for it
jerky is offline   Reply With Quote
Old 04-08-2016, 10:10 AM   #126
wicked1's Avatar
For me I do appreciate all the advice but I am deciding on a GMC 2500HD or Ford F-350 either 2015-2016 both Super Crew Short Box Configurations. I am going to buy new this one time and like my usual maintain it very well, so that being said anything I buy will last I am looking for the Cheaper models not spending 60-70+ K.....I will not look back and I will buy as I want, I looked at all three and the most fitting solutions for me are the two I mentioned. The F250 has 700lbs less payload and 600lbs less towing capacity for the same $ as an F350 so to me not worth it.
Good luck and Safe Trails to all you fellow campers, be safe and Happy Camping 🤗
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-08-2016, 10:52 AM   #127
CWSWine's Avatar
Good luck and Safe Trails to all you fellow campers, be safe and Happy Camping ��
I think you find that on the yellow door sticker on 3/4 ton diesel will be less than 2500 lbs payload and fully loaded with options in will be closer to 2250 lbs payload. With a 1 ton diesel you see payloads around 3750 and maybe a fully loaded one at 3300lbs. That is a big difference when comes to 5er you can haul and stay within the truck specs.
If was going to order one or get one from another dealer I would put in the buy order that if the yellow sticker wasn't at certain number I could refuse and get back my deposit.
My 2013 Chevy 2500HD Diesel had 2475Lbs
My 2015 Ford 1 Ton Diesel has 3744 lbs.
Anyone have examples of payload on 3/4 diesel or 1 ton diesel payload numbers?
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-08-2016, 11:03 AM   #128
Kenny kustom's Avatar
2014 ram 2500 diesel. Under 2k payload.
2015 ram 3500 diesel. Around 3k
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-08-2016, 11:32 AM   #129
Too Tall's Avatar
This is mine.
https://drive.google.com/file/d/0BxW...ew?usp=sharing
USMC 68 -70
Old 04-08-2016, 11:54 AM   #130
wicked1's Avatar
Interesting F350 fuel mileage data
Wait I am confused how do the MFG's advertise that the F350 and other HD trucks have payloads around 3800 when your telling me it is much less? I see all sorts of 5th wheels bigger then one I am getting towed by F350 3/4 ton trucks. I am not buying a Dually just to tow a light 5th wheel that is nuts.
Am I to understand the Crusader I want which has a pin weight of 2000 lbs and dry weight of 10,000lbs may not be able to be towed correctly by an F350 with a max tow of 15,700 and payload of 3800?
f350, mileage
