Old 04-04-2016, 08:47 PM   #61
wicked1's Avatar
Originally Posted by blwnsmoke View Post
I get 6,300 miles on a tank of DEF.
You won't have 3850 payload.. it will be about 3,100 payload. Then add your family, hitch and any other gear in the truck. Then take your pinweight and add a few hundred more to that since you will have gear in the 5th basement and front room.
If you are going to have your dealer do all the services, I'd recommend buying the maintenance plan. It is cheaper then paying for each service separately and my contact will sell them for $100 over cost.
Why the short payload when Ford says 3850? The trailer I am looking at is 2000 hitch and 9980 dry weight. The FDW and I and some gear we do not carry much but once I get the F350 I have less to worry about then my F150 which would be at max Payload and little wiggle on towing max.
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-04-2016, 09:04 PM   #62
If syou are going to have your dealer do all the services, I'd recommend buying the maintenance plan. It is cheaper then paying for each service separately and my contact will sell them for $100 over cost.
3100 may be a little low. My 2016 F350 Lariat has a payload of 3573 lbs. a platinum may be slightly less because it has a few bells and whistles my Lariat does not, but it's still an awesome truck. You are correct about subtracting passengers and gear from the payload. Also back out the weight of tools and whatever hitch you choose, which is another reason I like the B&W turnoverball in the truck, and a Goosebox on the fiver. Solves a lot of issues.
You will really enjoy the truck.
With 30,000 miles on it, you have 6,000 miles of bumper to bumper remaining. You might ask the dealer to pull the maintenance records before committing. Just to see if anything has happened. Not 100% but still good info.
The def is no big deal as long as no one has put def in the diesel tank. I buy my def at Sams Club where it is a little over $10 per 2.5 gal. The truck will use a lot more def when towing. The DIC will give you a warning when there is 800 miles worth of def remaining. Ford really should have a gauge showing def levels.
Good luck
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 04-04-2016, 09:20 PM   #63
CWSWine's Avatar
Which Crusader are you looking at?
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-04-2016, 09:39 PM   #64
I bought a 2012 F-250 with a 6.7 3 years ago. I usually get about 13 - 14 around town and 16 - 17 running at about 65mph. I have had a few 20mpg trips on stock wheels and tires but ended up switching to something snowflake rated and a bit wider since the stock Michelins were horrible in the snow here.
powerstroked is offline   Reply With Quote
Old 04-04-2016, 09:43 PM   #65
I was also going to mention anyone with a newer truck should really look into an Edge Insight. They are just monitors and plug into the OBD II port and show whatever sensors you want to see. Best $300 I have spent on my truck.
Old 04-04-2016, 10:06 PM   #66
Too Tall's Avatar
Yea, all RAM MPG dash readouts lie also. I calculated it once and it's about .5 mpg less than the readout. Since the readout is higher, I choose to go with that, ha.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-04-2016, 10:12 PM   #67
Too Tall's Avatar
Yes, I have one also. Love the info. I wish they'd do away with the pith and roll on every screen. No sure what's useful about that. My screen could be brighter but the thing reads every PDI in the computer.
USMC 68 -70
Old 04-05-2016, 12:14 AM   #68
Payload for every configuration is different, my 2014 f350 is 3451
jerky is offline   Reply With Quote
Old 04-05-2016, 07:08 AM   #69
Kenny kustom's Avatar
Don't believe any payload or " dry" weights of either the truck or tailer.
Weigh them yourself. You will find, everything weighs more than they say.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-05-2016, 08:28 AM   #70
wicked1's Avatar
2015 315RST same layout as the 295 but getting better shower for the Future Wife, she just got into Camping bc of Me, I was willing to give it up for her but we found a happy median
f350, mileage
