Old 04-05-2016, 08:42 PM   #81
My 2003 KENWORTH has a c15 caterpillar 6nz serial number which is pre egr and its oil stays brown til around ten thousand miles, and my 2014 powerstroke which the egr stopped working for some reason has clean oil til about 7,500 miles
jerky is online now   Reply With Quote
Old 04-05-2016, 09:03 PM   #82
Too Tall's Avatar
Yea, same here. EGR's a soot sucker.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-05-2016, 09:03 PM   #83
2007 WildCat 32QBBS
05CrewDually's Avatar
You can thank ultra low sulfur fuel for that.
Whether it's a Cummins, International (6.9 and 7.3 idi turbo & non-turbo, 7.3 di, 6.0), Isuzu, Detroit, Cat, JohnDeere, VW/Audi, ect. that I've owned or work on, the oil ends up black. It may take a little longer nowadays for some thanks to ultra low sulfur. Alot of the DI diesels, even after oil is drained, still have a few quarts of old black oil in the high pressure system so upon startup it mixes with new oil turning it black.
Your Kenworth holds probably as many as 4 times as much oil so of course it will take longer to appear black. Also if you're running a by-pass filter it will help.
As a side note, if the oil wasn't black I'd be more concerned because it's job, among others, is to carry contamination to the filter(s).
To wrap it up it makes no difference EGR or not and black diesel oil is no indication of a problem, it's a way of a diesel's life.
05CrewDually is offline   Reply With Quote
Old 04-05-2016, 09:23 PM   #84
SeaDog's Avatar
My 6.0 on a 3000 mile round trip no faster then 70 mph got 19.6 overall. I have a 40 hp FICM download and 5" exhaust. Got 16 pulling the 26 Flagstaff TT from Spokane to Weiser. OH ya no cat either.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 04-05-2016, 09:25 PM   #85
How many gallons of oil does that Cat engine take at oil change?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 04-05-2016, 09:26 PM   #86
Yes it is, has been since its introduction
Thank ultra low sulfur for what? Keeping my oil clean? I thank ultra low sulfur for injector rattle, I thank pre egr and egr delete for clean oil
Old 04-05-2016, 09:29 PM   #87
It takes 10.5 gallons
Old 04-05-2016, 09:29 PM   #88
SeaDog's Avatar
Don't follow Ford's schedule for cleaning the egr, I do mine every oil change and replace the O rings and gasket every other time.
Retired Navy
Old 04-05-2016, 09:35 PM   #89
2007 WildCat 32QBBS
Sulfur is one of the contaminants of oil via piston ring blowby during combustion.
Majority of the engines I listed above do not have EGR systems at all and always had black oil. EGR systems cycle and sample exhaust back into the intake only when certain parameters are meant. They are more off then on. They are not what dirties oil. It's been happening since the start.
Old 04-05-2016, 09:39 PM   #90
Sorry 05 crew I didn't get your whole post before I replied. No bypass on the kW, I won't run synthetic in semi so no reason to, dirty oil to me is a sign of a poorly running/tuned engine, egr makes oil dirtier, I didn't think anyone would disagree with that. I got writers cramp.
f350, mileage
