04-05-2016, 08:42 PM
#81
My 2003 KENWORTH has a c15 caterpillar 6nz serial number which is pre egr and its oil stays brown til around ten thousand miles, and my 2014 powerstroke which the egr stopped working for some reason has clean oil til about 7,500 miles
04-05-2016, 09:03 PM
#82
Yea, same here. EGR's a soot sucker.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
#83
2007 WildCat 32QBBS
You can thank ultra low sulfur fuel for that.
Whether it's a Cummins, International (6.9 and 7.3 idi turbo & non-turbo, 7.3 di, 6.0), Isuzu, Detroit, Cat, JohnDeere, VW/Audi, ect. that I've owned or work on, the oil ends up black. It may take a little longer nowadays for some thanks to ultra low sulfur. Alot of the DI diesels, even after oil is drained, still have a few quarts of old black oil in the high pressure system so upon startup it mixes with new oil turning it black.
Your Kenworth holds probably as many as 4 times as much oil so of course it will take longer to appear black. Also if you're running a by-pass filter it will help.
As a side note, if the oil wasn't black I'd be more concerned because it's job, among others, is to carry contamination to the filter(s).
To wrap it up it makes no difference EGR or not and black diesel oil is no indication of a problem, it's a way of a diesel's life.
04-05-2016, 09:23 PM
#84
My 6.0 on a 3000 mile round trip no faster then 70 mph got 19.6 overall. I have a 40 hp FICM download and 5" exhaust. Got 16 pulling the 26 Flagstaff TT from Spokane to Weiser. OH ya no cat either.
Retired Navy
2016 Flagstaff 26 FKWS
04-05-2016, 09:25 PM
#85
How many gallons of oil does that Cat engine take at oil change?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
04-05-2016, 09:26 PM
#86
Yes it is, has been since its introduction
Thank ultra low sulfur for what? Keeping my oil clean? I thank ultra low sulfur for injector rattle, I thank pre egr and egr delete for clean oil
04-05-2016, 09:29 PM
#87
It takes 10.5 gallons
#88
Don't follow Ford's schedule for cleaning the egr, I do mine every oil change and replace the O rings and gasket every other time.
Retired Navy
04-05-2016, 09:35 PM
#89
2007 WildCat 32QBBS
Sulfur is one of the contaminants of oil via piston ring blowby during combustion.
Majority of the engines I listed above do not have EGR systems at all and always had black oil. EGR systems cycle and sample exhaust back into the intake only when certain parameters are meant. They are more off then on. They are not what dirties oil. It's been happening since the start.
04-05-2016, 09:39 PM
#90
Sorry 05 crew I didn't get your whole post before I replied. No bypass on the kW, I won't run synthetic in semi so no reason to, dirty oil to me is a sign of a poorly running/tuned engine, egr makes oil dirtier, I didn't think anyone would disagree with that. I got writers cramp.
04-05-2016, 09:42 PM
#91
Roughly what can you expect to pay for an F350 SCREW SB. I went to a dealer today the MSRP was $70K they gave me $3500 in rebates and they offered me a final price of $63 on a Platinum with the 8 foot bed. Needless to say I did not think it was a good enough deal so I walked. I figure in a $70 MSRP I should be able to get it for $58 at least? I am going to look at a GMC 2500HD tomorrow, we will see but I am swaying toward the Ford.
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
04-05-2016, 09:49 PM
#92
2007 WildCat 32QBBS
I'm a " buy used, repair myself" type guy so I would not pay that. But, you have a price to beat now so I'd try other Ford dealers too and see what kind of deal they offer. I hope you told the salesman your going to look at a GM tomorrow. If he has your phone number I'd think he will be calling.
04-05-2016, 09:59 PM
#93
2007 WildCat 32QBBS
Typer's cramp. No problem. Diesels been apart of my whole life starting as a child with my dad when he was an OTR owner/operator. From equipment to trucks I've worked on alot and had the pleasure of owning some.
The first impression I got from earlier posts was EGR is the reason diesel oil gets black. It's simply not the case, proven by earlier non-EGR diesels. I like to try to educate and separate fact from lore.
No harm, keep on truckin!
04-05-2016, 10:07 PM
#94
I paid 62 for mine but that was a couple years ago. Interesting enough me and the wife were driving through the local dealer the other day and they had a f350 platinum srw for 69k and an f350 lariat dually for 68k.
04-05-2016, 10:10 PM
#95
He knows bc my Fiancé is good friends with the GMC General MGR. so they rough quoted me for a 2500 HD SLE Loaded with Duramax $53 for a white SCREW SB AWD
I am also thinking hard about a 2015 F350 Lariat with all the bells and whistles has 32K with 6.7 and I can easily get that for under $50 so I may go that way as I baby everything and will have Ford do all the maintenance. It has a 100% clean carfax
04-05-2016, 10:14 PM
#96
Yes just mis communication/impression. I've been in love with trucks my whole life and after years of working for people I'm trying to wear out my second truck that I own.no worries
#97
2007 WildCat 32QBBS
Under 50? Is that your price? I might have to take a ride north.
04-05-2016, 10:21 PM
#98
Now for those truck lovers and to lighten the mood
04-05-2016, 10:37 PM
#99
Oklahoma Proud
It's hard to get many rebates this time of year.
Honestly you could probably get a new gmc denali for mid to upper $50s if you look around. I did and it's a 3500 4wd dually.
Best I've seen on nicer diesels(not base or work trucks) about the best you are going to get is about $8-10k off msrp but its probably not going to be till late summer or until a new body style comes out for prices to get there.
I've always been a gm guy, but i looked at f350 platinums and king ranches just to keep an open mind, but they couldn't compare to the denali for price, features and such.
04-05-2016, 10:48 PM
#100
2007 WildCat 32QBBS
NICE Jerky! Visor looks great. Function & looks, can't beat it.
