Old 02-25-2016, 07:16 PM   #1
Interesting F350 fuel mileage data
I had some business about an hour from home yesterday (58 miles one way). So I took the Ford F-350 and once I cleared town, I set the cruise at 47 mph for about 20 miles. I was on a secondary 2 lane country road, flat ground with really light traffic. Fuel mileage on the lie-o-meter started dropping and settled out at 14.7 mpg. I've noticed this phenomenon before, and just blamed it on the hills where I was at the time. I then bumped the speed up to 60 mph, reset the cruise, and fuel mileage began to creep up peaking at 22.1 mpg. Weird...
Obviously I'm a little dismayed at the crappy low speed mileage, especially since I'm hard pressed to explain it. Very happy with the high speed,...except that I have to question the accuracy of the display.
Thoughts?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 02-25-2016, 07:26 PM   #2
davel1971's Avatar
probably was going through a regen cycle. It drops to about that for about that long
David & Lynn
Old 02-25-2016, 07:46 PM   #3
JohnF's Avatar
F350 on trip across state not pulling last weekend.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 02-25-2016, 07:47 PM   #4
Mine is similar. It really likes somewhere around 60.
At 47 mph, was it still in sixth or did it drop back to fifth?
2017 Ford F450 Lariat 6.7L
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 02-26-2016, 12:16 PM   #5
Medic97's Avatar
My F250 has shown similar behavior. The sweet spot appears to be between 62 - 67 mph. Anything above or below these speeds, the mileage suffers right away.
Robert & Wendy M
5er: 2016 Columbus 320RS - TV: 2015 F250 6.7L V8 Diesel
Part-timer; Looking forward to fulltime...
Medic97 is offline   Reply With Quote
Old 02-26-2016, 12:32 PM   #6
OntarioFireFighter's Avatar
I'll second the regen cycle...
I see the exact same behaviour and comparable mileage numbers, when mine's running a regen.
If you don't notice the quick pop-up, saying that a regen is running, there's no other indication on the dash/screen, other than the drop in mileage.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 02-26-2016, 12:37 PM   #7
I have gotten similar results with my 2015 Duramax. Best mileage has been 23.8 mpg at about 65 mph.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 02-27-2016, 08:43 PM   #8
KFX, it was definitely in 6th. Yep, being in regen cycle is the only logical explanation. I'll have to repeat the rest.
Thanks all
d
Old 02-28-2016, 06:22 AM   #9
World Wide Wanderer
wahoonc's Avatar
Watch your RPM's that is a better indication of where your engine's sweet spot is than MPH. I haven't had to deal with the regen stuff... I have a 7.3 It does it's best mileage at about 1850 RPM, which with the current gearing is around 58 mph. As a general rule I try to stay under 2,000 RPM with that motor.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 02-28-2016, 06:39 AM   #10
nomad297's Avatar
When empty, my 2015 Chevy 3500 6.0 with 4.10 gets its best fuel mileage at around 60-63mph, which, on flat roads is right at 19mpg. When that speed drops or increases on the same roads, the fuel mileage suffers. I'd say what you experienced is normal. My "testing ground" is I-295, The Baltimore/Washington Parkway from DC to Baltimore, very early in the morning.
Bruce
f350, mileage
